Requesting creation of watch face [Bip Max]
Johnnysiwy
- Has thanked: 1 time
Hi everyone,
I would love to use pipboy watch face on my bip max without those extra spaces becouse while currently using bip 6 version of face https://amazfitwatchfaces.com/bip/view/45156 it leave some space due to bip max having bigger screen.
- Has thanked: 429 times
- Been thanked: 2132 times
Johnnysiwy wrote: 19 Jun 2026, 16:19Hi everyone,
Upload Version 3
- Fixed issue line progress and add Distance's unit "Kilometers , Miles"
Full AOD ( no seconds , no animation ) QR code for install watchface : The QR code is generated using catbox as the file storage location. At certain times, if there are many users, the installation may fail. Please wait and try installing again.
Both QR codes have been tested for installation. Therefore, if the installation fails, it may be because the server has a large number of users, or the file may have been removed from the server. I will not repeat this process.
AOD Same as Original : QR code for install watchface : The QR code is generated using catbox as the file storage location. At certain times, if there are many users, the installation may fail. Please wait and try installing again.
Johnnysiwy
I tested on my watch and found some issue about line progress , So I fixed and add Distance's unit
you can download again in download post
viewtopic.php?p=22390#p22390
hello, can transfor this watchface to bip max in spanish and add aod with time, calendar and batery?
https://amazfitwatchfaces.com/bip/view/44585
thanks very much
thanks very much
If you want to make a request that is not related to the original text or watchface in first request, please start a new topic to avoid confusion.deybit wrote: 12 Jul 2026, 14:35hello, can transfor this watchface to bip max in spanish and add aod with time, calendar and batery?
thanks very much
Regarding your request, the owner has stated:
"Use your own inspiration before copying from someone else."
Therefore, if you want to be converted, it is recommended to obtain permission from the owner first.
Or, it would be more appropriate to request the owner to do it for you.
berzectyve
hey asoo! thank you for making these.asoo wrote: 19 Jun 2026, 17:49Johnnysiwy wrote: 19 Jun 2026, 16:19Hi everyone,
If the requester has not yet asked for permission from the owner of the work to adapt it. If the owner requests deletion, I will delete it immediately.Preview and Download
Upload Version 3
pipboy_en_v3_interactive_re_Bip_Max_FullAOD.zip
pipboy_en_v3_interactive_re_Bip_Max_AOD_Same_ORG.zip
first of all, i just newbie in here. i set my theme for my bip max with scan qr code. and then i search the pipboy for bip max. and i found these thread. i just wanna set my bip max for your customization pipboy, but.. i dont know how to apply this theme for my watch. where do i found? can you make a that qr code for these theme? or i just using coding for apply this theme? can i get the tutorial? thank you, man!
You can found how to make QR for install in this link :berzectyve wrote: 01 Aug 2026, 04:12hey asoo! thank you for making these.asoo wrote: 19 Jun 2026, 17:49Johnnysiwy wrote: 19 Jun 2026, 16:19Hi everyone,
Upload Version 3
berzectyve
hello! thank you for replying this! i just tried with that tutorial on your link. but.. its too complicated for me.. (bcs im too newbie for this) when i upload the files, and get to in zink for the QR, when i scanning in zepp is always failed..asoo wrote: 01 Aug 2026, 07:35You can found how to make QR for install in this link :berzectyve wrote: 01 Aug 2026, 04:12hey asoo! thank you for making these.asoo wrote: 19 Jun 2026, 17:49
Upload Version 3
so.. maybe i'll wait for people uploading the QR for this theme pipboy. i love it so much! and thank you for the reply!
berzectyve wrote: 01 Aug 2026, 08:55hello! thank you for replying this! i just tried with that tutorial on your link. but.. its too complicated for me.....
A QR code has been added to the download thread. The link is below.
berzectyve
bro.. i appreciate this. thank you so much, man!asoo wrote: 01 Aug 2026, 11:26berzectyve wrote: 01 Aug 2026, 08:55hello! thank you for replying this! i just tried with that tutorial on your link. but.. its too complicated for me.....
