Request for gtr4 watchface
- Wahwah
- Has thanked: 107 times
- Been thanked: 3 times
Hi, can someone create this watchface in English for gtr4 please?
Can it be without the bright part in the bottom of the background i think it is radar seconds style also without the progress bar in both sides
Thanks https://play.google.com/store/apps/deta ... x&hl=en_US
- Wahwah
If it is possible for this watchface to be created i would like just two backgrounds options the grey and the olive green please, Simple version not as complicated as the original watchface but with the date format like the pictures in the first post
- Has thanked: 417 times
- Been thanked: 2086 times
Understand before downloadingWahwah wrote: 15 Jun 2026, 14:19If it is possible for this watchface to be created i would like just two backgrounds options the grey and the olive green please, Simple version not as complicated as the original watchface but with the date format like the pictures in the first post![]()
Actually, you should be able to do it yourself; it's just changing the AppID. watch face in file app.json.Wahwah wrote: 15 Jun 2026, 16:55Type 2 looks amazing better than i thought
Thanks you.
Is it possible to have both faces on the watch?
When i downloaded type2 in the watch the first version disappeared![]()
However I've already done it for you. You can download again in last Download post
viewtopic.php?p=22362#p22362
