Request to create a watchface for bip 6
Sharif
Post by Sharif »
Hello.
I have a request to you
1. Make a watchface like bip 5 numbering watchface ( hour in the front and minutes in the backward) it was a default digital watchface of bip 5.
Link :
View Rhythm for Bip 5 on Zepp Explorer:
https://ze.mmk.pw/view/8454400/116004/latest
MarioLie
Has thanked: 57 times
Been thanked: 37 times
Post by MarioLie »
The hour has to be in the back unfortunately.
Preview
Bip6.zip
(337.1 KiB) Downloaded 39 times
Has thanked: 437 times
Been thanked: 2141 times
Sharif wrote: 04 May 2026, 04:46
Hello.
Link :
I've also ported this watchface. So I'm posting it here as another option for you.
Can switch widget ( power,steps, calories, HeartRate , Stand) same as Bip5 , But use custom script to switch you can switch by click on icon widget
Preview and download
Rhythm_Bip_6.zip
(350.29 KiB) Downloaded 322 times
Sharif
Post by Sharif »
The zip file is not downloaded.
Sharif wrote: 04 May 2026, 08:52
if you mean my zip file , I tested it can download normally.
I no idea why you can not download ??
I tested install it work normally
Preview
