Creation / Duplication of Watchface, willing to pay [T-Rex 3 Pro 48mm]
Puckersunch
Post by Puckersunch »
Hi All,
I am currently using a Watchface from the Zepp App (Pure Mountains Turntable).
However I would like some modifications:
  • Replace the mountain and Turntable at the top with a Heart Rate Indicator by Zone, similar to the one by Polar in the image below, watch on the right.
  • Add a progress bar for Standing in addition to the number
  • Change the Date format to German (23/04 THU -> Donnerstag 23.04.)
  • Remove 24h/AM/PM Indicator
  • Add small seconds display to time since the turntable is gone.
Please contact me, if you are able to make this.
Has thanked: 436 times
Been thanked: 2137 times
The watch face you want modified is a paid one, so finding the original file would be difficult.
As far as I know, if you've already purchased it and your phone is rooted, you might be able to find the original file on your phone.
Otherwise, you'll have to wait for someone who has the original file and is willing to help you.
Or, you'll have to create it from scratch using a sample image.
This may result in the finished product not matching the original.
Puckersunch
That is what I thought, I also tried finding a way to contact the creator of it, but I have been unable to find them anywhere outside of the Zepp app (which does not support contacting the creators). I have bought the watch face and I like it but would want it elevated. I am also open to suggestions for similar watch faces that fit my bill, however a lot of times some key design factors are (in my eyes) wrong with alternatives, like having heart rate as a progress bar or having battery prominently as a progress bar instead of as a small bar. Also a lot of watch faces seem to ignore the standing Part :D
I'm not sure if this is what you're looking for.
If it's still not what you need, please try modifying it yourself.
This watchface can be edited with the SashaCX75 's editor.
viewtopic.php?p=22130#p22130
PureMountainsTurntable.zip
(149.59 KiB) Downloaded 49 times
