Help......Watch face for Amazfit balance
vietnam1234
I try to find this watch face (in the attached file). Do any one have this watch face for Amazfit balance. Please give me the QR, thanks
- Has thanked: 420 times
- Been thanked: 2120 times
https://ze.mmk.pw/view/8519936/119276/1.0.4
vietnam1234
Thanks for your help. but the watchface you sent in the comment is different from the one I find. the centre is different and the seconds hand is smootherasoo wrote: 01 Apr 2026, 03:03https://ze.mmk.pw/view/8519936/119276/1.0.4
What's different about the center? Do you mean the background isn't completely black, or the center hand clock is different? Regarding the smooth second hand, you can edit it to Analog pro type 2 using the sashacx75 editor. I recommend using only type 2 because other types will have problems with the latest Balance firmware.vietnam1234 wrote: 01 Apr 2026, 03:24Thanks for your help. but the watchface you sent in the comment is different from the one I find. the centre is different and the seconds hand is smootherasoo wrote: 01 Apr 2026, 03:03https://ze.mmk.pw/view/8519936/119276/1.0.4
Link to Program editor : viewtopic.php?p=11643#p11643
As for the center, if you mean the background, you can unpack and edit the image as you like , by using the sashacx75 editor for unpack.
Regarding the hand clock, I think it looks the same as the image you provided.
This is an example modified according to my understanding, using the sashacx75 editor. If you want to make further modifications, you can try doing it yourself.
