Help......Watch face for Amazfit balance
vietnam1234
Post by vietnam1234 »
I try to find this watch face (in the attached file). Do any one have this watch face for Amazfit balance. Please give me the QR, thanks
Been thanked: 2122 times
vietnam1234 wrote: 01 Apr 2026, 02:32
Preview
https://ze.mmk.pw/view/8519936/119276/1.0.4
vietnam1234
asoo wrote: 01 Apr 2026, 03:03
Preview
Thanks for your help. but the watchface you sent in the comment is different from the one I find. the centre is different and the seconds hand is smoother
vietnam1234 wrote: 01 Apr 2026, 03:24
Preview
What's different about the center? Do you mean the background isn't completely black, or the center hand clock is different? Regarding the smooth second hand, you can edit it to Analog pro type 2 using the sashacx75 editor. I recommend using only type 2 because other types will have problems with the latest Balance firmware.
Link to Program editor : viewtopic.php?p=11643#p11643
As for the center, if you mean the background, you can unpack and edit the image as you like , by using the sashacx75 editor for unpack.
Regarding the hand clock, I think it looks the same as the image you provided.
Preview
This is an example modified according to my understanding, using the sashacx75 editor. If you want to make further modifications, you can try doing it yourself.
This QR code links to the file-hosting website Catbox.
If you are unable to install it, it may be because many people are using it. Please wait a moment and try again. If it still doesn't work, it may be because Catbox is not available in your region.
Delicacy.zip
(210.86 KiB) Downloaded 63 times
