watchface request for GTS3
molnarmilan000
- Has thanked: 5 times
- Been thanked: 2 times
- Has thanked: 436 times
- Been thanked: 2137 times
I don't know if you're asking because you want to build it yourself, or if you're just asking to see if it's possible.
If you want to build it yourself, it is possible. As for how, the answer is you need to be able to write scripts and understand the calculations of the watch face.
And you need to actually do it.
From the image you provided, it appears to be a Binary Watch.
The model you mentioned can be created using the script provided in the attachment.
This is just an example to show that if you understand the calculations of the watch face and know how to write scripts, you can create a watch face. I will not proceed with any further action or explain the script. If you want to understand, try finding by yourself
or use AI to answer your question.
I do not have GTS3 so this watchface I tested it on my Bip6 , it's work normal
But I think it's can work on GTS3 to Because this API1 The watch face is designed to demonstrate that if you can write scripts and understand the clock's calculations, you can create it. Therefore, if you wish to proceed further, please do so yourself. I am not interested in taking any further action.
molnarmilan000
