watchface create request for GTS3
molnarmilan000
- Has thanked: 5 times
- Been thanked: 2 times
Hi, I brought a few pictures of the dials I would like to see on the GTS3 watch, but when I tested the dial creator, it seemed a little complicated to me, so I need to delve deeper into it to be able to use it myself. I'll show you a few that I'd like to see and test on the GTS3 watch.
MarioLie
- Has thanked: 56 times
- Been thanked: 37 times
Here's the look you asked for.molnarmilan000 wrote: 03 Jan 2026, 11:14Hi, I brought a few pictures of the dials I would like to see on the GTS3 watch, but when I tested the dial creator, it seemed a little complicated to me, so I need to delve deeper into it to be able to use it myself. I'll show you a few that I'd like to see and test on the GTS3 watch.
- Attachments
molnar.zip- (91.66 KiB) Downloaded 80 times
molnarmilan000
molnarmilan000
I found one like this:
https://amazfitwatchfaces.com/mi-band-7/view/841
How difficult is it to make?
molnarmilan000
molnarmilan000
- Has thanked: 436 times
- Been thanked: 2137 times
You hold the position of Watchface Maker. If you want to see this watchface on your device, I think you should be able to create it yourself. It shouldn't be difficult for you as a Watchface Maker (WF maker).
Here is an example resource for the numbers and background.
I think you can create a GTS3 watch face yourself using this.
Resource and Preview
This is not a watchface. This is just an images resource used to create a watachface.
Tool and Editor for create Watchface that use ZeppOS
viewtopic.php?p=21581#p21581
All the resources provided are enough to create a watch face similar to the example image.
MarioLie
I have tried to fulfill your request in the example image "Click kwh"
I tried to make it display the "hours" as per the template, with one dial showing 1-12.
And the "Minute" is also done according to the template.
Hopefully, it meets your requirements.
However, in the AOD section, the hours will display like the minutes because displaying the hours with a single dial showing 1-12 requires a custom script that refreshes, consuming power, which is not suitable for AOD.
Watch Face Click kwh
molnarmilan000
hello, thank you, i will try it.
thank so much for these things.
MarioLie
Last thememolnarmilan000 wrote: 05 Jan 2026, 17:11hello, thank you, i will try it.
- Attachments
minute.zip- (152.31 KiB) Downloaded 72 times
molnarmilan000
molnarmilan000
molnarmilan000
hello MarioLie , The last thing you did doesn't show the time correctly, even though it works fine, because when I looked at the source code in the zip file, you did it by the minute, and single-handed watches work differently.
