Some needed edits please
Has thanked: 114 times
Hi, would someone please help editing this watchface that i need for my daily use?
If possible convert it for gtr4 so it is properly centered.
Also i really need the max and min heart rate reading included in the heart graph
And please reduce the size of the hours and minutes digits and make it off white so they are not too bright
Thank you
https://amazfitwatchfaces.com/gtr/view/35664
Has thanked: 429 times
Been thanked: 2132 times
Wahwah wrote: 03 Dec 2025, 03:50
Thank you
Editing a watch face from a scripted watch face that doesn't conform to the existing editor's standards is difficult, so I had to rebuild it and test it on a real device. I created and tested it on my Bip6 before porting it to GTR4.
The changes I made to the original are as follows:
- No have function graphs selection for other widgets. Because as far as I've tested, the original watchface it didn't display graphs for other widgets, it can display only heart Rate , so I will not do this function.
- The size and color of the time, date, etc. were slightly reduced, as requested.
- The maximum and minimum pulses were increased, as requested.
P.S. If you really need your request, please be patient and don't delete it too quickly. You can leave the request for a month, and if no one responds, deleting it won't hurt.
Preview & Download
Refined_Chart_L_GTR_4.zip
(196.42 KiB) Downloaded 105 times
Thank you so much i really needed this heart graph watchface i appreciate it 🙏
danielmartis
Post by danielmartis »
Dobrý večer,dala by sa táto verzia urobiť aj pre gtr 3?za prípadnú prácu ďakujem.
danielmartis wrote: 07 Dec 2025, 16:23
I can convert it to GTR3 for you , but I'm not sure if the graph will display. If I remember correctly, after firmware update (I'm not sure which version.) , But after that update, have some users said that users found that the heart rate graph didn't display or displayed incorrectly.
However, I can't confirm this because I no longer use GTR3.
I'm pretty sure the graph isn't displayed or isn't displayed correctly on GTR3 ( Zepp OS 1).
However, I can't verify 100% this because I don't have a GTR3.
Refined_Chart_L_GTR_3.zip
(194.79 KiB) Downloaded 103 times
danielmartis
Ahojte , použil som túto tvár na T Rex 2 a zatiaľ vypadá že graf pracuje správne.dakujem
