• Адміністратор
Request for watchface for the amazfit balance
Модератори: asoo, Watchmens
Правила форуму
Відповісти
piotarock
З нами з: 22 серпня 2024, 07:53
Контактна інформація:
Повідомлення piotarock »
Hello members,
I came across these two watchfaces in Zepp App and I would like to request for them to be ported for the balance.
Kind regards.
Востаннє редагувалось 02 червня 2025, 09:39 користувачем piotarock, всього редагувалось 1 раз.
Аватар користувача
Been thanked: 2120 times
Повідомлення asoo »
piotarock писав: 02 червня 2025, 06:09
Hello members,
Kind regards.
Зображення
Зображення
In my opinion, if the watch face is a paid watch face and it is in the ZeppOS system, you should try to find a way to contact the creator to make according to your request.
Or if you want to ask someone to convert it for you, I think you should pay for buy the original and bring the original to request to do what you want.
However, it is just my personal opinion. If you think what you do is appropriate, then do it as you see fit.
P.S.
I do not intend to criticize the requester in this post.
But I am concerned about those who want to help because if the owner of the work finds out that his work has been modified without permission, the one who will suffer is not the requester but the helper because the owner may accuse the helper of violating his rights.
Previously, I received a request to convert a watch face from another system to zeppOS. In the end, I was criticized by the owner of the work. I don't need to say much. If it were a watch face in the same system, the helper would not be able to avoid being criticized by the owner of the work.
Therefore, I would like to recommend that if you want to convert someone's work, please ask for permission from the owner first. Or if the work costs money, you should contact the owner directly.
piotarock
asoo писав: 02 червня 2025, 09:13
Hello members,
Kind regards.
Зображення
Зображення
P.S.
I understand. No problem
Відповісти
Повернутись до “Watchfaces creation (order table)”
Хто зараз онлайн
