request for a watch face
Rafi87
Post by Rafi87 »
hello
could someone please create these watch faces for me in a PDS file?
I don't want what I marked green, instead of the flashlight indicator I would like something else, something combined with red, maybe move the circles differently, and combine with red and the digital one can be like the one in the photo, I would have already edited it according to myself in PSD
can I send the font for the digital one
thanks in advance
Has thanked: 409 times
Been thanked: 2037 times
I'm not sure what you want.
But I have this watchface image in CPT format which I made long time ago. However, it will be slightly different from your example.
The image have objects separated so they can be moved.
However, I don't use photoshop, so this file is "save as PSD" from corel photo. I'm not sure how accurate the object separation is.
I hope it's useful to you.
Keepimproving480x480.zip
(973.37 KiB) Downloaded 51 times
I'm not sure what size you need.
The image watchface file is 480x480.
If it's not the right size, I think you can reduce the size yourself.
Since you can use Photoshop.
Rafi87
Post by Rafi87 »
thank you very much
photoshop supports the CPT format and I opened the file without any problems
the size I need is 466x466 px but I will adjust that :)
thank you again
