Error generating GIF when creating the watchsface.
Hello, I need to help me because when I try to generate a Watchface GIF, it generates an error, although then I package the Watchsface, I send the file in case you can help me, thank you.
- Attachments
ISAAC BLANCO--.zip- (564.69 KiB) Downloaded 98 times
- Has thanked: 414 times
- Been thanked: 2073 times
The problem is that in the AOD section you enable Analog but there is no image specified to show Analog Hands.
If you don't want to use it, you can delete it by pressing the trash can icon or disable it by clicking on the eyeball to create a line cross out it. And now you can create a GIF as usual.
