Fix request for GTR4
Has thanked: 107 times
Hi, this watchface is one of my favorite, could someone please fix the flickering seconds hand? And also if possible could someone remove the blue shades in the gray background that is shown in the image and make the background solid gray?
Thanks everyone
viewtopic.php?p=18419#p18419
Been thanked: 2086 times
Wahwah wrote: 24 Mar 2025, 21:54
Thanks everyone
In the part of color, I can't do it because I don't have GTR4 and from testing on simulator, no blue is found, it only shows gray color gradient.
However, I tried to change the background to gray color not gradient,
and tested on simulator, no color gradient is found. If it still shows blue in GTR4, I can't help anymore.
In the part of color on real device, I recommend the owner who uses it to try to fix it by themselves, it will be the most accurate.
But if you can't fix it yourself for whatever reason, this is all I can help you with.
Fixed issue the seconds hand :
Wow it is all fixed now, seconds is working like a charm and the background is nice and clean without any blue shades. I think you are right the problem was the gradient because i had this issue with other watchface with gradient backgrounds. Thank you sir so much i appreciate it
@asoo sorry to bother you i just noticed that the hour hand is two hours ahead, i remember we had this issue when it was created and you were able to fix it by switching it to 12H i think. Also it is missing the preview image it is empty circle
Wahwah wrote: 25 Mar 2025, 02:19
Fixed Download again :
Thank you 🙏
