Simple watchface with rotating seconds
Has thanked: 107 times
Hi, can someone please make this watchface for GTR4 please? Maybe with better quality and improved font graphics.
Thank you
https://play.google.com/store/apps/deta ... S-zDLl7VmA
Been thanked: 2086 times
Wahwah wrote: 03 Feb 2025, 02:06
Thank you
Woldt.zip
(191.89 KiB) Downloaded 96 times
I can do this by reducing the overall brightness to make the fonts less bright. This is the final edit for this work. If you want to make further edits, please do it yourself.
WoldtV2.zip
(214.58 KiB) Downloaded 91 times
It is perfect as always thank you so much 🙂
If it is not too much trouble is it possible to add a dimmer to reduce the brightness of the white font as needed? Just to make the white gray or amoled a little
Wahwah wrote: 03 Feb 2025, 16:51
viewtopic.php?p=19916#p19916
Thank you sir it is brilliant best watchface ever
