MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
hist
Post by hist »
Hello!
For some reason whenever I try to open the application it just pops up for a second than closes tried all the downloadable versions.
Could someone tell me if I also need to install something else in order to run the application?
Thanks,
Hist
lvpokka
Post by lvpokka »
[mention]hist[/mention] PLEASE read Carefully !!!
hist
Post by hist »
ohh sorry. thanks for the fast answer
noooooo
Post by noooooo »
I successfuly decompiled, modified and recompiled an amazfit bip res using the mi band 4 tool watchface.exe. As the original amazfit tools is not update and it will lead to errors if used. It can cause a brick using a res modified with this tool in my amazfit bip? Do you know if an updated version of amazfit tools for amazfit bip exists?
lvpokka
Post by lvpokka »
[mention]noooooo[/mention] ???? Whaaaat ))) How do we should know in Mi Band 4 forum section... Mi band 4 tool is only for mi band 4 tool...
noooooo
Post by noooooo »
lvpokka wrote: 15 Jul 2019, 13:38
@noooooo ???? Whaaaat ))) How do we should know in Mi Band 4 forum section... Mi band 4 tool is only for mi band 4 tool...
I'm asking the dev, as the base of the decompiler is the same as the amazfit bip One, Just with an higher number of colours available
lvpokka
Post by lvpokka »
There is also different structure of objects, and yes, mi band 4 allow HQ images to be used... That's mean that Bip is not supporting that king of image... Therefor restrictions are used for Bip
noooooo
Post by noooooo »
lvpokka wrote: 15 Jul 2019, 14:17
Many thanks, do you know if an updated version compatible with amazfit bip Is present somewhere? Sorry for the OT, I will close it here
jfernandezcaro
Post by jfernandezcaro »
Where is located a full-list of accepted commands and how to use them?
In other hand, Animations are supported but in TOP of all. Could be possible to support Background animations? (so numbers and icons can be on top of it)
lvpokka
Post by lvpokka »
[mention]jfernandezcaro[/mention] we also testing this option, but no luck... animation will always be on top for now
jfernandezcaro
I found out a complete list of accepted parameters on a chinese forum called bandbbs. Attached, I hope it helps:
It contains 2x json files. One with Chinese explanations, another in plain format.
Also a picture showing how it looks like.
jsonfiles.zip
(4.14 KiB) Downloaded 349 times
pagdot
Post by pagdot »
jfernandezcaro wrote: 15 Jul 2019, 19:23
I've translated the notes to english (using Google Translate), but couldn't find a meaningful translation for the last line:
offset coordinate 指的是被遮住后offset 的coordinate ,在复联四表盘中有体现,各位可以试试
english.zip
(2.61 KiB) Downloaded 339 times
yzx_28
Post by yzx_28 »
pagdot wrote: 15 Jul 2019, 20:58
I am the author of this document, I am honored that you use it to perfect the unpacking tool. I don't fully understand the "offset coordinate" that you said. But my friend, after a lot of tests, he knows "offset coordinates". After a while I will do a series of tests. I will tell you the results when I finish.
I said "在复联四表盘中有体现,各位可以试试" means the performance in the special version of the Avengers's Xiaomi Band 4
I don't know which version will be released in countries other than China.
Although I don't know the specific principle of it, I can tell you that the icon (power, Bluetooth, do not disturb) on this version of the dial will move, which is related to X2 Y2.
I want to ask a question, can you find a way to solve the problem of not displaying the weather?
My English is not so good, so I used Google Translate
luka97
Post by luka97 »
I'm at a loss. After 3 hours of searching and trying different combinations I still have some problems with my watchface (attached below)
  • The day of week is off by one (today should be MAR (tuesday) but it shows MER (wednesday)
  • The activity bar (the pink bar) is never full, it stops at 80%
  • The status icons (Bluetooth, Dnd and Lock) are not displayed correctly (activating DnD show the lock icon, locking the display doesn't show any icon)
  • Some glitches in the GIF preview that I was not able to test on the device like one of the activity progress icons is shown over the battery bar (the purple bar) and the first image of the battery bar (under 10% battery) is shown over the orange ruler
The json should be correct as I triple checked it. Thanks in advance to everyone that is able to help me.
custom.rar
(189.24 KiB) Downloaded 277 times
lvpokka
Post by lvpokka »
@l[mention]luka97[/mention] check image 34, it's not used but its shifting all images to +1))))
it's easy to check it in logs
Trace|Loading image 33...
Trace|Loading resources for 5 'Date'
Trace|Loading resources for 5.1 'MonthAndDay'
Trace|Loading resources for 5.1.1 'SeparateMonthAndDay'
Trace|Loading resources for 5.1.1.1 'Number'
Trace|Loading resources for 5.1.1.1.5 'TextAlignment'
Trace|Loading resources for 5.1.1.3 'Number'
Trace|Loading resources for 5.1.1.3.5 'TextAlignment'
Trace|Loading resources for 5.1.3 'Boolean'
Trace|Loading resources for 5.1.4 'Boolean'
Trace|Loading resources for 5.2 'ImageSet'
Trace|Loading image 34...
luka97
Post by luka97 »
Thank [mention]lvpokka[/mention], that was it. I checked the log for errors but there were non that mattered, and I ignored everything else since the log is so long. Maybe an unused image should fail the build, or at least give some kind of warning.
lvpokka
Post by lvpokka »
Wf creation only for best of the best 😁😁😁😁 Im helping users with good WFaces or ideas, hate this 100500 Wf with just changed background e.t.c
marcmc
Post by marcmc »
I am creating a watchface but the status icons don't work. I tried everything ant I don't see any error in the logs... I attach the folder, any help will be appreciated.
masquefans.zip
WatchFace
(158.99 KiB) Downloaded 250 times
NikGud
Post by NikGud »
lvpokka wrote: 17 Jul 2019, 12:03
Hi! i have some problem with temperture on my WF. Maybe i make it with mistake?
Can you check it?
https://amazfitwatchfaces.com/mi-band-4/view/1383
p.s.
(sorry for my bad english))
lvpokka
Post by lvpokka »
[mention]NikGud[/mention] temperature not working for now...
[mention]marcmc[/mention] user for all statuses x2=12 y2=0 x3=1 and you have allot of problems with coordinates and positioning
marcmc
Post by marcmc »
lvpokka wrote: 19 Jul 2019, 07:39
@NikGud temperature not working for now...
@marcmc user for all statuses x2=12 y2=0 x3=1 and you have allot of problems with coordinates and positioning
I tried doing this in all statuses and still don't work :( Also... what kind of problems with coordinates and positioning? I did everything based on other watchfaces adapting it to my design...
ColinLaughton
Post by ColinLaughton »
Hi all,
I want to completely create a wf using this tool initially to unpack the bin file, edit the images and alter the json file so I have full control of image placement. I mean, where the time, steps, battery etc are in the finished face.
Is there a recommended way to do this?
Is there existing software to assist?
I use windows (regrettably) so not sure if anything is out there yet.
I’ve opened the json file in notepad but wonder if this is suitable.
Thanks,
Col
Bartosz066
Post by Bartosz066 »
ColinLaughton wrote: 20 Jul 2019, 12:14
Hi all,
Thanks,
Col
Use MiBandWFTool_1.3.6.zip. Read README.txt.
Notepad is ok but you can use notepad plus plus.
I'm terrible in drawing. Can you make for me some graphic? I would like to change icons to text: km, steps and bpm. And you are welcome to make improvements :)
https://amazfitwatchfaces.com/mi-band-4/view/1278
coolmyll
Post by coolmyll »
Using version 1.3.6 i am getting this error when i tried to make an animated watchface:
Error|[WARN] This image is using too many palette colors. Please make image less colorful.
The final .bin cannot be synced to the band.
coolmyll
Post by coolmyll »
ormaken wrote: 24 Jul 2019, 17:23
Could someone help me? I can't solve it...
Error code 1:
Trace|8 'Status'
Debug|Generating previews...
Error|[ERROR] error while rendering
Error|[ERROR] error while rendering (...)
Error code 2:
I have used indexed mode of GIMP-255 colors but it is not solved.
I managed to solve it by saving it as 8bit and in PaintNET. Also i replaced transparency with black color but i dont know if that has anything to do with it fixed.
