MiBandWFTool
lvpokka
Has thanked: 19 times
Been thanked: 152 times
MiBandWFTool
Post by lvpokka »
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
zmr1992
Post by zmr1992 »
user_test wrote: 12 Jul 2019, 07:18
zmr1992 wrote: 12 Jul 2019, 07:03
How do you synchronize bin files larger than 300kb to the bracelet?
You can't, that's why the PalleteImage version of the Tool is very interesting. Because with that tool you are supposed to get lower size bins altought you get poor quality.
But as you can read in my earlier messages, there seems to be a problem with the tool and the images compressed are not shown in Mi Band 4.
I am waiting for the author of the tools to have a fix for that
Yes, I saw someone uploading a dial file larger than 300kb. I wonder if someone can actually brush it in? :lol:
DarkForgotten
Post by DarkForgotten »
I changed the order of png and how json load them and the date is OK. The problem is the time now...
thankkien
Post by thankkien »
DarkForgotten wrote: 12 Jul 2019, 08:53
I think you should post your entire project to the cloud, we will help you
lukbe
Been thanked: 8 times
Post by lukbe »
lvpokka wrote: 11 Jul 2019, 19:32
lukbe wrote: 11 Jul 2019, 17:27
lvpokka wrote: 11 Jul 2019, 17:09
@lukbe Please provide files, i will verify)
please swap in json
Activity <-> Date
its wrong position thats why he skip it on miband4
I did change, however situation is still same. Gif looks good, after loading bin in to MB - weekday is not displayed.
00_v2_czech_04072019_packed.7z
(256.42 KiB) Downloaded 248 times
lvpokka
Post by lvpokka »
looks like its different type of storage and Palette now is not supporting transparency...
Please use real colors for (fake)transparency to match background color! there is only chance to use good quality with low resolution palette image.
DarkForgotten
Completed!
I have renumbered all the pngs and edited the json, this have solved the number issues.
Created new pngs for hours and minutes, use the same for both created some conflicts.
Added the 21 chinese pngs for week day and added 7 for italian language.
Now it works! Thanks for the help.
lvpokka
Post by lvpokka »
Stable v1.3.6
https://yadi.sk/d/7CFMjn5qSvmARA
Anonymous86
Post by Anonymous86 »
[mention]lvpokka[/mention]
Yeah thank you for your time. I knew that where was some false values. I tried to understand what some json values do.
I thought the "BottomRight" etc. wasn't necessary, because "TopLeft" theoretical seems to be enough.
I still don't understand what is X2,X3,Y2 ???
I also copy and pasted your json example but i still get false rendering. :?:
And what tool do you used for the screenshots? Selfmade? :)
lvpokka
Post by lvpokka »
[mention]Anonymous86[/mention] check if all images are used! you should not have unused resources
+ tool from screenshot is rebuilded from amaizfit wf editor on JS
Anonymous86
Yeah thank you very much. I forgot one index.
What do you mean with "JS" ?
lukbe
Post by lukbe »
lvpokka wrote: 12 Jul 2019, 10:42
I changed transparency at weekday and situation is still same. After loading WF in to mi band, week day is not displayed.
I always use type of compilation: RawImageMode
00_v4_czech_12072019_kroky_Baterie_procenta_dny_trans_no.7z
(247.45 KiB) Downloaded 234 times
user_test
Post by user_test »
lvpokka wrote: 12 Jul 2019, 10:48
Stable v1.3.6
I have test this version with images without any transparency, and it still doesn't work.
The watchface in the miband is all black, can't see anything.
lukbe
Post by lukbe »
I think that for MB4 must be always loaded 21 weekdays (7+7+7). In the case when I load only 7 pics, on the Mi band is not week day displayed - I tried to change language of the MB4 to Chinese, after this change was my pic displayed...
Anonymous86
Does calories already supported? It doesn't show in the preview
lvpokka
Post by lvpokka »
[mention]Anonymous86[/mention] calories not supported yet
[mention]lukbe[/mention] same problem, just added 21 weekdays 1-14 single pixel, last 7 normal
UPD>
v1.3.6
-palette mode fix
Andreunto
Post by Andreunto »
Waiting for calories in preview. 1.3.6 is good tool
kry008
Post by kry008 »
Can someone describe this tool?
lvpokka
Post by lvpokka »
[mention]kry008[/mention] read topic "How to"
lukbe
Post by lukbe »
Will you create a graphical application?
Or exist app for live view of the json file and possibility to edit this file? Something like app on this web page for cor and bip.
Thank you
lvpokka
Post by lvpokka »
[mention]lukbe[/mention] I have modified it, but it's working partly, I updated it only for json debug. Don't want to make it public and then answer on allot of questions 😅😅😅
lukbe
Post by lukbe »
Can you send me a link to this app?
Turko9999
Post by Turko9999 »
how can we edit .json file? Need to be a programmer? I want to design watchface from blank but i dont know how can i do. Anybody can help me about it or do we have any graphic enabled modifying tools?
Turko9999
Post by Turko9999 »
Hey guys,
I downloaded and changing pngs of the gif(already same size) but compiler gives me error
Fatal|System.Collections.Generic.KeyNotFoundException: Verilen anahtar sözlükte yoktu.
   konum: System.ThrowHelper.ThrowKeyNotFoundException()
   konum: WatchFace.Parser.Writer.Write(IList`1 descriptor)
   konum: WatchFace.Program.WriteWatchFace(String outputDirectory, String outputFileName, String imagesDirectory, WatchFace watchFace)
How can i mod the .json file?
spongebob.zip
(170.71 KiB) Downloaded 264 times
Turko9999
Post by Turko9999 »
And also i have background problem with this theme, i change it from photoshop keeping same settings but not working. Everything works except background 0000.png image. Also i need help for them too :/
galatasaray_packed.bin
(72.67 KiB) Downloaded 261 times
lvpokka
Post by lvpokka »
[mention]Turko9999[/mention]
Spongebob, please save all spangbob images to 32bit there is some problems with pixels, im using Paint.Net
Galatasary, looks like image should be packed as RAW, read logs
Trace|BPP: 8, PaletteColors: 2890, Transaparency: False
Error|[WARN] This image is using too many palette colors. Please make image less colorful.
