Regular face just like AOD default [T-Rex 2]
dmurcho
Post by dmurcho »
Hi all
Is there a regular watch face just like the AOD default for t-rex 2 (see pic)? Can anyone make one if there isn't already one?
Cheers,
Desi
Has thanked: 419 times
Been thanked: 2104 times
dmurcho wrote: 19 Aug 2024, 12:43
Hi all
Cheers,
Desi
Trex2AOD.zip
(38.6 KiB) Downloaded 104 times
dmurcho
Post by dmurcho »
Thank you so much! Great work.
I did not manage to install it using any of the explained methods, though. I install regular faces from you and others using this app. Could you put it for download on the app itself? Thanks and sorry for my clumsiness.
You can upload to the web with your ID
https://amazfitwatchfaces.com/upload
and install via AmazFaces app
viewforum.php?f=23
