Please port "PICK (C) LOCK" to gtr4
Has thanked: 114 times
Hey Boss @asoo can we get a version for GTR4? I couldn’t pass on this beautiful watchface 🙂
Has thanked: 430 times
Been thanked: 2132 times
Wahwah wrote: 11 Aug 2024, 20:27
@Wahwah
Next time, if possible, please check the topic before posting.
You have requested GTR4 in the topic that requested GTR3.
If the topic does not match your device, please open a new topic.
For the benefit of searchers who use the same device as you.
This time, I have split your post to make a new topic.
It will work properly on Zepp OS Version 3.x or higher.
PICK(C)LOCK_GTR_4.zip
(914.41 KiB) Downloaded 106 times
GTR3pro :
viewtopic.php?p=18816#p18816
Wow this very impressive watchface nice work i appreciate you
Next time i will make sure i post in the right topic thank you 🙂
Has thanked: 205 times
Post by amazfitfacesafrica »
Very nice watchface and work. Is it possible to make it for GTR3 Pro? Of course without compass because I try to convert myself but with no success. Thank you.
amazfitfacesafrica wrote: 12 Aug 2024, 10:25
I didn't plan to make this watch face for ZeppOS 1.0-2.x
because this watch face uses several scripts that only work on ZeppOS 3.x or higher.
I am not sure about the accuracy of the display
- Weather forecase in ZeppOS 1
And I guess ZeppOS 1 can not display
- Compass pointer
- Temp. Graph
However, if you want, I have done it
But I must inform you that the operation of all 3 items mentioned may not work properly or cannot work and I cannot fix anything
And I will not fix anything further
And I made another version by changing the compass to Wind direction.
PICK_C_LOCK_GTR_3_Pro.zip
(884.39 KiB) Downloaded 98 times
Version change compass to wind direction
PICK_C_LOCK_GTR_3_ProWind.zip
(916.06 KiB) Downloaded 94 times
Thank you, asoo. Both versions works flawlessly. Weather forecast works fine too.
