Port for GTR 4
mrbutthead
Has thanked: 60 times
Port for GTR 4
Post by mrbutthead »
Hi everyone, Please port this watch face to GTR 4. Thanks.
https://www.facer.io/watchface/A0RK1IJ1 ... ilqmarshal
Has thanked: 415 times
Been thanked: 2082 times
mrbutthead wrote: 09 Aug 2024, 17:49
VIGILANT2_CLPlus_GTR_4.zip
(293.46 KiB) Downloaded 130 times
Has thanked: 205 times
Post by amazfitfacesafrica »
Very nice watchface. Is it possible to make it for gtr3 pro? I try to convert myself but with no success.
mrbutthead
@asoo thanks man
amazfitfacesafrica wrote: 10 Aug 2024, 09:47
You should have mentioned more about how you couldn't convert, what problems you encountered that made it impossible, you just said it couldn't, I couldn't fix the problem directly either.
I'm not sure why you can't convert it.
I tested it and it converts normally and works.
Except you can't show Compass because zeppOS 1 can't use compass on screen.
When you unpack it you won't find Weather icon in editor because it uses user_script to handle it. But when you pack it as watchface and bring it use, you will find Weather icon on real device.
Thank you for info. The icon weather indeed not showing in editor and i suppose something is wrong with convert but you are right, in reality weather icon appears,. Thank you.
