Rquest for Create a Watchface for GTR 4
Hasnain732
- Has thanked: 7 times
- Has thanked: 430 times
- Been thanked: 2132 times
Understand before downloadingHasnain732 wrote: 20 May 2024, 16:16please port this for gtr 4Spoiler
https://www.facer.io/watchface/OSCusj8o ... atch4black
- Has thanked: 205 times
- Been thanked: 5 times
I try to convert it for GTR3 Pro with no success while there is no compass. Only altimeter. Can convert it for GTR3 Pro with no altimeter of course. Thank you.
???? There is no compass on this dial, only wind direction.amazfitfacesafrica wrote: 21 May 2024, 05:20I try to convert it for GTR3 Pro with no success while there is no compass. Only altimeter. Can convert it for GTR3 Pro with no altimeter of course. Thank you.
And in the Barometer section in ZeppOS 1, if I remember correctly, ZeppOS 1 cannot display Altitude on the dial. But it can be displayed as pressure data.
If you want to display Barometer data on ZeppOS1, you can change it to display as pressure.
Example: This watch face has been edited to show Barometer as Pressure instead of Altitude.
Thank you, asoo. Yes i say while there is no compass in this watchface cannot convert properly. I say that because when a watchface contains compass sasha editor 10.4 can't convert it properly. And yes zepp os 1.0 can't show altimeter in a watchface, only barometer can show in a watchface.
Hasnain732
thanks alot for this hard work..
brother can you give me the link of watchface editor beta v11 link?
The beta version is not yet available for download to the public.Hasnain732 wrote: 21 May 2024, 12:17thanks alot for this hard work..
Because it is still in the testing phase and adding capabilities.
When completed, SashaCX75 ( program owner) will open it up for download to the public by himself through the relevant forum.
Hasnain732
can you please make the AOD battery-friendly? by making of this in 2 varients, 01 is turning off the smooth second to normal secondsasoo wrote: 21 May 2024, 12:48The beta version is not yet available for download to the public.Hasnain732 wrote: 21 May 2024, 12:17thanks alot for this hard work..
and a 2nd version with seconds off.
thanks
Hasnain732
thanks
thanks
I'm actually not going to make any further edits to the dial I've already completed. As informed previously But due to the power reasons you mentioned. I will do it for you.Hasnain732 wrote: 21 May 2024, 13:19can you please make the AOD battery-friendly? by making of this in 2 varients, 01 is turning off the smooth second to normal seconds
thanks
But after this operation, I request no further corrections.
Turning off "analog smooth seconds" and replacing it with "analog seconds" does not save power.Both elements consume almost the same amount of energy.
If you want to save energy "Analog smooth seconds" and "Analog seconds" must be disabled entirely if you choose to have either of them on. It consumes almost the same amount of energy.
Turning off digital seconds can help save energy. I agree with this.
But actually the original dial and the dial as you want, the energy consumption is not much different. It may reduce energy consumption by 3%-10% per 1 charge, depending on the usage characteristics of each person.
