Rquest for Create a Watchface for GTR 4
Hasnain732
Has thanked: 7 times
Post by Hasnain732 »
please port this for gtr 4
https://www.facer.io/watchface/OSCusj8o ... atch4black
Screenshot 2024-05-20 211834.png (95.32 KiB) Viewed 1498 times
Been thanked: 2120 times
Hasnain732 wrote: 20 May 2024, 16:16
GTR4:
OMG_212_GTR_4.zip
(593.9 KiB) Downloaded 121 times
Amazfit Balance:
https://amazfitwatchfaces.com/balance/view/964
Has thanked: 205 times
Post by amazfitfacesafrica »
I try to convert it for GTR3 Pro with no success while there is no compass. Only altimeter. Can convert it for GTR3 Pro with no altimeter of course. Thank you.
amazfitfacesafrica wrote: 21 May 2024, 05:20
???? There is no compass on this dial, only wind direction.
And in the Barometer section in ZeppOS 1, if I remember correctly, ZeppOS 1 cannot display Altitude on the dial. But it can be displayed as pressure data.
If you want to display Barometer data on ZeppOS1, you can change it to display as pressure.
Example: This watch face has been edited to show Barometer as Pressure instead of Altitude.
OMG_212_GTR_3_Pro.zip
(570.4 KiB) Downloaded 141 times
Thank you, asoo. Yes i say while there is no compass in this watchface cannot convert properly. I say that because when a watchface contains compass sasha editor 10.4 can't convert it properly. And yes zepp os 1.0 can't show altimeter in a watchface, only barometer can show in a watchface.
Hasnain732
thanks alot for this hard work..
brother can you give me the link of watchface editor beta v11 link?
Hasnain732 wrote: 21 May 2024, 12:17
The beta version is not yet available for download to the public.
Because it is still in the testing phase and adding capabilities.
When completed, SashaCX75 ( program owner) will open it up for download to the public by himself through the relevant forum.
Hasnain732
asoo wrote: 21 May 2024, 12:48
can you please make the AOD battery-friendly? by making of this in 2 varients, 01 is turning off the smooth second to normal seconds
and a 2nd version with seconds off.
thanks
Hasnain732
thanks
Hasnain732 wrote: 21 May 2024, 13:19
thanks
I'm actually not going to make any further edits to the dial I've already completed. As informed previously But due to the power reasons you mentioned. I will do it for you.
But after this operation, I request no further corrections.
Turning off "analog smooth seconds" and replacing it with "analog seconds" does not save power.Both elements consume almost the same amount of energy.
If you want to save energy "Analog smooth seconds" and "Analog seconds" must be disabled entirely if you choose to have either of them on. It consumes almost the same amount of energy.
Turning off digital seconds can help save energy. I agree with this.
But actually the original dial and the dial as you want, the energy consumption is not much different. It may reduce energy consumption by 3%-10% per 1 charge, depending on the usage characteristics of each person.
