Convertion to GTR 4 (maybe)
Hi there, Im wondering if this watch face could be ported to GTR 4, looks really nice and smooth.
Lattenknaller
- Has thanked: 60 times
- Been thanked: 146 times
I have this to offer. WF is ready, I just need to implement the script for the color change.
Let me know if it fits, because some things are different
mrbutthead
- Been thanked: 5 times
- TRK88PL
- Has thanked: 67 times
- Been thanked: 40 times
If You can please also make Gtr 3 version, I can convert this ofc from gtr 4 to 3,but if You can please make also gtr 3 version, looks nice and I was thinking about my own recreation of this watchface, but this moving seconds method are not to easy (for me) to implement... Specially for Gtr 3 watch.
- Has thanked: 429 times
- Been thanked: 2132 times
It's an interesting dial.
I have tried to built . "Circular seconds" same as the original watchface
Anyone interested, can bring it to edit. You can proceed as you wish.
The dial can switch heart and temp by click on it's area
This watch face uses a user_ script to create, so anyone who wants to edit it. must be fixed by editing the code directly in the index.js file.
Cannot be edited with the editor because have some new function has been created that does not exist in the editor.
I made this dial for myself. and request not to accept any further amendments
Version 2.4 For Balance
https://amazfitwatchfaces.com/balance/view/744
For the GTR4 all three models were made to test the conversion of the 11 beta, so these three models were only tested on Editor program and not on real devices. Those interested in using it, please manage the risk yourself.
GTR3pro :
Because ZeppOS 1 cannot display some elements, So GTR3pro and GTR3 will display Temp. differently.
viewtopic.php?p=18094#p18094
GTR3 :
viewtopic.php?p=18097#p18097
GTR4 :
Download Balance , GTR4 , GTR3PRO , GTR3
GTR3pro :
GTR3 :
GTR4 :
Hi mate, looks really nice, i'll gladly take a shot but unfortunately theres no link to download your file. Could you maybe re attach, please? Thanks.
Fantastic work with the seconds, unfortunately I cant fully test due to hardware limitations (Im on GTR 4 and as you stated before, seems theres some troubles with the editor to fully port the script: weather / heart shortcuts got overlapped)asoo wrote: 25 Apr 2024, 22:10Spoiler
The attached file is the "amazfit balance" watch face.
The dial has no shortcuts.
This watch face uses a custom script to create, so anyone who wants to edit it. must be fixed by editing the code directly in the index.js file.
Cannot be edited with the editor because a new function has been created that does not exist in the editor.
I made this dial for myself. and request not to accept any further amendmentsattached file for those interested in editing by yourself
combat_CustomScript_Balance.zip
Anyways, I will look forward Lattenknaller's job to do its magic with his project which I could probably test in a more appropiate way.
For the GTR4, GTR3, GTR3PRO, all three models were made to test the conversion of the 11 beta, so these three models were only tested on Editor program and not on real devices. Those interested in using it, please manage the risk yourself.
You can download it according to the link.
viewtopic.php?p=18057#p18057
Tested (GTR4), fantastic recreation. Top class job, props mate!asoo wrote: 28 Apr 2024, 16:59For the GTR4, GTR3, GTR3PRO, all three models were made to test the conversion of the 11 beta, so these three models were only tested on Editor program and not on real devices. Those interested in using it, please manage the risk yourself.
The script works flawlessly: colors, seconds, shortcuts.
Since theres still the editor limitation, could you please modify AOD to not show heart rate/temp, steps, and battery info (just to keep screen refresh as low as posible, for battery life sake) I tried myself but got buggy when repack...
Thank you!
- Has thanked: 205 times
I test GTR3 Pro version and there's a problem. Temperature not showing at all and there's a dash in its place and it's visible to heart rate too. O attach photos to see you. Everything else works fine. Thank you for this lovely watchface.
AOD No ( rate/temp, steps, and battery info )AWfan wrote: 28 Apr 2024, 22:14Tested (GTR4), fantastic recreation. Top class job, props mate!asoo wrote: 28 Apr 2024, 16:59For the GTR4, GTR3, GTR3PRO, all three models were made to test the conversion of the 11 beta, so these three models were only tested on Editor program and not on real devices. Those interested in using it, please manage the risk yourself.
Thank you!
Thank you for reporting the test results.
The problem may arise from the limitations of Getting variable values
If I remember correctly zeppOS 1 cannot display "center temp" in tilted corner.
Therefore causing the problem of not displaying the "center temp" value.
This problem I can't fix. Because it is a restriction of the OS.
I will remove version GTR3 and GTR3pro from the download list.
Thank you for reporting the results.
Wonderful, thank you!asoo wrote: 29 Apr 2024, 00:22Spoiler
Thank you!
combattaddscriptV2_2_2_sasha_GTR_4aod.zip
Because I like this watchface can you add GTR3 Pro version and remove current temperature completely and leave heart rate only. Everything else is ok. Thank you.
Thank you for reporting the test results.amazfitfacesafrica wrote: 29 Apr 2024, 04:15I test GTR3 Pro version and there's a problem. Temperature not showing at all and there's a dash in its place and it's visible to heart rate too. O attach photos to see you. Everything else works fine. Thank you for this lovely watchface.
When I get back to my hotel, I'll try it out.
Lattenknaller
Sorry, I've been very busy the last few days. I assume that I do NOT have to push my version any further? Then I can concentrate on the next project.
Good work, Asoo
Good work, Asoo
This watch face I used Editor Version 10.4 to pack.amazfitfacesafrica wrote: 29 Apr 2024, 04:15I test GTR3 Pro version and there's a problem. Temperature not showing at all and there's a dash in its place and it's visible to heart rate too. O attach photos to see you. Everything else works fine. Thank you for this lovely watchface.
I think it's possible to use 10.4 unpack, however I haven't tested it.
So if you want to edit more, editor Version 10.4 can be used for operations.
This watch face I tested on editor and ZeppPlayer only.
GTR3Pro+Temp.: GTR3PRO no Temp.:
Thank you, asoo. Both versions you attach works fine. Thank you and have a nice day and week.
- TRK88PL
This version for Gtr 3 pro working fine on gtr 3, but of course it's cutted, so should be converted to display correctly, but seconds and move are displayed correctly, if You want to knowasoo wrote: 29 Apr 2024, 06:25Spoiler
This watch face I tested on editor and ZeppPlayer only.Spoiler
GTR3Pro+Temp.:
combatt_GTR3PRO_Weather.zip
GTR3PRO no Temp.:
combatt_GTR3PRO.zip
Actually, you can convert it yourself.TRK88PL wrote: 29 Apr 2024, 08:07This version for Gtr 3 pro working fine on gtr 3, but of course it's cutted, so should be converted to display correctly, but seconds and move are displayed correctly, if You want to knowasoo wrote: 29 Apr 2024, 06:25Spoiler
GTR3Pro+Temp.:
GTR3PRO no Temp.:
combatt_GTR3PRO.zipcan You convert for Gtr 3 this version, @asoo ? Thx.
After converting, you just edit the numbers in user_script.js
to be compatible with GTR3 (this can be done by changing all the numerical values to be compatible with GTR3, GTR3pro and GTR3 are 0.94584 different, so you just multiply this value with the existing value and edit it back in) e.g.
pos_x: 240 - 62,
240x(454/480) gets an approximate value of 227
62x(454/480) gets an approximate value of 59
and change it like this
pos_x: 227 - 59,
Do this with every number that is in user_script.js
Then pack it and you will have a dial that works properly on the GTR3.
But if you can't do it, you can download it from the link below.
Whoever uses it, please manage the risk yourself.
Your creations are always welcomed, would be nice to see another aproach to the same project but only if you're in the mood and with some spare time, of course.Lattenknaller wrote: 29 Apr 2024, 05:19Sorry, I've been very busy the last few days. I assume that I do NOT have to push my version any further? Then I can concentrate on the next project.
Good work, Asoo
To be honest asoo's work has been impressive with this WF.
PS: Looking forward your next project!
Lattenknaller
As I was almost finished, I didn't want to withhold my version from anyone. So here it is:
tab the digital seconds will change the color and long press the digital seconds will switch between smooth or ticking seconds or hide the analog second
- Attachments
COMBAT_GTR_4.zip- GTR4
- (341.3 KiB) Downloaded 131 times
COMBAT_BAL.zip- Balance
- (301.45 KiB) Downloaded 117 times
