How to install watchfase (file zip) BIP5
domenicopardo
Post by domenicopardo »
Please help me install a dial made with What Face editor by SashaCX75, on a BIP 5?? Which Android app should I download on my mobile phone? Thanks to who helps me
(Per favore mi aiutate ad installare un quadrante fatto con What Face editor di SashaCX75 , su un BIP 5 ?? Quale app Android devo scaricare su cellulare ? Grazie a chi mi aiuta)
Has thanked: 414 times
Been thanked: 2073 times
domenicopardo wrote: 08 Mar 2024, 17:32
AmazFaces APP (Android)
viewtopic.php?p=1308#p1308
This program you can use to sync the Bip 5 watchface to your watch.
Can be done 2 ways
1. Get the watch face from https://amazfitwatchfaces.com and install it.
2. sync dial file.zip You can go directly to the watch.
domenicopardo
I thank you so much . Can you explain point 2 better to me?
domenicopardo wrote: 09 Mar 2024, 10:43
Have you installed the program successfully ?
If the installation is complete, enable it when entering the watch face selection page.
Below you will find 5 icons.
If you want to send a zip file, click on the rightmost icon that is an arrow pointing down.
Then follow the steps the app recommends and you can install it.
I think the program is easy to use, You just have to understand a little it and you can definitely use it.
domenicopardo
Perfect ! everything works great. Sorry and thank you so much
Users browsing this forum: Calgaryben and 1 guest
