Hi all,
i'm trying to covert the fallout pipboy for the gts4 made by El_WIndows95 to the Amazfit Active.
The conversion worked well, but now that i'm trying to make some edits, they don't work. The animation in the middle shows up fine in the tool, but when i try it on my watch, it's absent. The rest work well.
Here's a link if you guys want to give a look at it
https://drive.google.com/file/d/12Ca8M8 ... sp=sharing
- Amministratore
issue animation after convert GTS4 to Active
Ultima modifica di Guerbest il 06 feb 2024, 16:17, modificato 1 volta in totale.
- Has thanked: 419 times
- Been thanked: 2104 times
@GuerbestGuerbest ha scritto: 06 feb 2024, 16:10Hi all,
The problem lies in the file name.
The "animation frame" file. It's must start at 0.
such as
This is an example that I edited according to animation requirements.
I can't test Because there is no "Amazfit Active."
But I think the animation should work properly. You can find this explanation in the editor.
in the description section
P.S. I think you posted in the wrong Topic. Now I moved to new Topic in forum Amazfit Active
Next time, please check before posting.
Sorry i didn't realize it was the wrong topic, i'll pay more attention in the future.
Thank you very much for your help! Now it works correctly
