- Administrador
Mi Band 8
Reglas del Foro
OutlawCecil
- Contactar:
Mi Band 8
Just got my Mi Band 8 and am eager to get a new watch face, since many of the ones offered have Chinese in them, even with the band being set to English.
Well, I poked around in the usual places and can't figure out if custom watch faces are even possible on this band. I was really hoping to see custom faces, but especially custom games! If anybody has found out anything on this, please let me know. I wish I could at the very least make my own for this watch (more-so than the built-in "custom" faces you can select from)
- GIK-Team
- root
- Has thanked: 1127 times
- Been thanked: 267 times
- Contactar:
I don’t think that there will be custom games and applications on it, but the dials most likely will definitely be.OutlawCecil escribió: 03 May 2023, 21:28Just got my Mi Band 8 and am eager to get a new watch face, since many of the ones offered have Chinese in them, even with the band being set to English.
it is... it toke me a while to understand the switch from Miband 6 to 7, but I have now a pretty cool understanding what is possible... so I just made MY themed watchface, but the code behind is pretty easy... just check it out https://amazfitwatchfaces.com/mi-band-7/view/424
Última edición por sodycc el 05 May 2023, 06:23, editado 1 vez en total.
- GIK-Team
- root
- Contactar:
In Smart Band 8, the watch faces are in the bin format, everything is different there.sodycc escribió: 04 May 2023, 07:42it is... it toke me a while ti understand the switch from miband 6 to 7/8 but I have now a pretty cole uhderstanding what is possible... so I just made MY themes wathcface, but the code behind is pretty easy... jst check it out https://amazfitwatchfaces.com/mi-band-7/view/424
Hi, there is a initial support for the Mi Band 8 in EasyFace.
Format is similar to the Smart Band 7 pro.......
- GIK-Team
- root
- Contactar:
There are currently no watch faces for Smart Band 7 pro.krukken escribió: 05 May 2023, 10:27Hi, there is a initial support for the Mi Band 8 in EasyFace.
I'm sorry but you are wrong!
- GIK-Team
- root
- Contactar:
You showed a picture, not the watch faces file itself. If you want to show something, please provide links or files. I do not deny that I could be wrong, but as you may have noticed, there is no section for this watch model on the site, since there are no watch faces and an active discussion of this topic.
What do you do with the file so you can not install it or open it. A file proves nothing, I could post any file.....GIK-Team escribió: 05 May 2023, 15:02You showed a picture, not the watch faces file itself. If you want to show something, please provide links or files. I do not deny that I could be wrong, but as you may have noticed, there is no section for this watch model on the site, since there are no watch faces and an active discussion of this topic.
7 pro and mi band 8 is not a product of amazfit (Huami)
- GIK-Team
- root
- Contactar:
Do you have a watch face file?krukken escribió: 05 May 2023, 15:24What do you do with the file so you can not install it or open it. A file proves nothing, I could post any file.....
Thanks for the info, but we know about it.
Yes,
Can you provide a tool for uploading it to the watch/Band ?
- GIK-Team
- root
- Contactar:
No we can not.krukken escribió: 07 May 2023, 07:17Yes,
OutlawCecil
- Contactar:
I'm lost. You mean "EasyFace for pebble"? That's all I can find when looking for anything "EasyFace"... What am I missing?krukken escribió: 05 May 2023, 10:27Hi, there is a initial support for the Mi Band 8 in EasyFace.
- GIK-Team
- root
- Contactar:
He most likely means this program: EasyFace_Gen2_Compiler_SB8OutlawCecil escribió: 08 May 2023, 17:58I'm lost. You mean "EasyFace for pebble"? That's all I can find when looking for anything "EasyFace"... What am I missing?
I have send you a PM with a pdf doc that explains a little bit on how to use it.OutlawCecil escribió: 08 May 2023, 17:58I'm lost. You mean "EasyFace for pebble"? That's all I can find when looking for anything "EasyFace"... What am I missing?krukken escribió: 05 May 2023, 10:27Hi, there is a initial support for the Mi Band 8 in EasyFace.
The only way for now to upload the WF to the Band/watch is to use a particular mod of Mi Fitness that use his own server and .........
- GIK-Team
- root
- Contactar:
Would you like to share this information with everyone? After all, everyone is interested in understanding the situation in more detail.krukken escribió: 09 May 2023, 07:25I have send you a PM with a pdf doc that explains a little bit on how to use it.
I'm sorry but I think you won't like it and you won't accept it so easily when you find out from which country the guy who made that Mi Fitness Mod and programmed the compiler from the EasyFace tool you posted.GIK-Team escribió: 09 May 2023, 10:29Would you like to share this information with everyone? After all, everyone is interested in understanding the situation in more detail.krukken escribió: 09 May 2023, 07:25I have send you a PM with a pdf doc that explains a little bit on how to use it.
The only way for now to upload the WF to the Band/watch is to use a particular mod of Mi Fitness that use his own server and .........![]()
- GIK-Team
- root
- Contactar:
We understand all this very well. And believe us, we know who is from which country.krukken escribió: 09 May 2023, 12:36I'm sorry but I think you won't like it and you won't accept it so easily when you find out from which country the guy who made that Mi Fitness Mod and programmed the compiler from the EasyFace tool you posted.
NinjaBreadMan
- Contactar:
Can someone help with band 7 or band 8 tools never was able to find one for 7 imagine 8 will be similar but would like to try and creat my own Luke with previous bands
Mongomery33
- Has thanked: 1 time
- Contactar:
Is there any tutorial to know how to use this tool? Thank you.GIK-Team escribió: 08 May 2023, 20:43He most likely means this program: EasyFace_Gen2_Compiler_SB8OutlawCecil escribió: 08 May 2023, 17:58I'm lost. You mean "EasyFace for pebble"? That's all I can find when looking for anything "EasyFace"... What am I missing?
- GIK-Team
- root
- Contactar:
There is some pdf file, but it is in russian. You can try to translate.Mongomery33 escribió: 23 May 2023, 11:00Is there any tutorial to know how to use this tool? Thank you.
Mongomery33
- Contactar:
Thank you so much for the tutorial.GIK-Team escribió: 23 May 2023, 13:24There is some pdf file, but it is in russian. You can try to translate.Mongomery33 escribió: 23 May 2023, 11:00Is there any tutorial to know how to use this tool? Thank you.
Panda35064
- Contactar:
Since the official dial of Mi Band 8 does not currently have a multi-language dial, it can only make a single-language dial. I am very helpless for the dial that only has Chinese. I also want to adapt to other languages, but I can't do this at present.
mister.mike
- Contactar:
MagiicMiind
- Has thanked: 3 times
- Contactar:
¿Quién está conectado?
