Mi Band 8
OutlawCecil
Mi Band 8
Post by OutlawCecil »
Just got my Mi Band 8 and am eager to get a new watch face, since many of the ones offered have Chinese in them, even with the band being set to English.
Well, I poked around in the usual places and can't figure out if custom watch faces are even possible on this band. I was really hoping to see custom faces, but especially custom games! If anybody has found out anything on this, please let me know. I wish I could at the very least make my own for this watch (more-so than the built-in "custom" faces you can select from)
Has thanked: 1162 times
Been thanked: 278 times
OutlawCecil wrote: 03 May 2023, 21:28
I don’t think that there will be custom games and applications on it, but the dials most likely will definitely be.
sodycc
Post by sodycc »
it is... it toke me a while to understand the switch from Miband 6 to 7, but I have now a pretty cool understanding what is possible... so I just made MY themed watchface, but the code behind is pretty easy... just check it out https://amazfitwatchfaces.com/mi-band-7/view/424
sodycc wrote: 04 May 2023, 07:42
it is... it toke me a while ti understand the switch from miband 6 to 7/8 but I have now a pretty cole uhderstanding what is possible... so I just made MY themes wathcface, but the code behind is pretty easy... jst check it out https://amazfitwatchfaces.com/mi-band-7/view/424
In Smart Band 8, the watch faces are in the bin format, everything is different there.
krukken
Post by krukken »
Hi, there is a initial support for the Mi Band 8 in EasyFace.
Format is similar to the Smart Band 7 pro.......
krukken wrote: 05 May 2023, 10:27
There are currently no watch faces for Smart Band 7 pro.
krukken
Post by krukken »
GIK-Team wrote: 05 May 2023, 12:43
I'm sorry but you are wrong!
krukken wrote: 05 May 2023, 14:51
You showed a picture, not the watch faces file itself. If you want to show something, please provide links or files. I do not deny that I could be wrong, but as you may have noticed, there is no section for this watch model on the site, since there are no watch faces and an active discussion of this topic.
krukken
Post by krukken »
GIK-Team wrote: 05 May 2023, 15:02
What do you do with the file so you can not install it or open it. A file proves nothing, I could post any file.....
7 pro and mi band 8 is not a product of amazfit (Huami)
krukken wrote: 05 May 2023, 15:24
Do you have a watch face file?
Thanks for the info, but we know about it.
krukken
Post by krukken »
GIK-Team wrote: 05 May 2023, 19:31
Yes,
Can you provide a tool for uploading it to the watch/Band ?
krukken wrote: 07 May 2023, 07:17
Yes,
No we can not.
OutlawCecil
I'm lost. You mean "EasyFace for pebble"? That's all I can find when looking for anything "EasyFace"... What am I missing?
OutlawCecil wrote: 08 May 2023, 17:58
He most likely means this program: EasyFace_Gen2_Compiler_SB8
krukken
Post by krukken »
I have send you a PM with a pdf doc that explains a little bit on how to use it.
The only way for now to upload the WF to the Band/watch is to use a particular mod of Mi Fitness that use his own server and .........
krukken wrote: 09 May 2023, 07:25
Would you like to share this information with everyone? After all, everyone is interested in understanding the situation in more detail. ;)
krukken
Post by krukken »
GIK-Team wrote: 09 May 2023, 10:29
I'm sorry but I think you won't like it and you won't accept it so easily when you find out from which country the guy who made that Mi Fitness Mod and programmed the compiler from the EasyFace tool you posted.
krukken wrote: 09 May 2023, 12:36
We understand all this very well. And believe us, we know who is from which country. ;)
NinjaBreadMan
Post by NinjaBreadMan »
Can someone help with band 7 or band 8 tools never was able to find one for 7 imagine 8 will be similar but would like to try and creat my own Luke with previous bands
Mongomery33
Post by Mongomery33 »
GIK-Team wrote: 08 May 2023, 20:43
Is there any tutorial to know how to use this tool? Thank you.
Mongomery33 wrote: 23 May 2023, 11:00
There is some pdf file, but it is in russian. You can try to translate.
Mongomery33
GIK-Team wrote: 23 May 2023, 13:24
Thank you so much for the tutorial.
Panda35064
Post by Panda35064 »
Since the official dial of Mi Band 8 does not currently have a multi-language dial, it can only make a single-language dial. I am very helpless for the dial that only has Chinese. I also want to adapt to other languages, but I can't do this at present.
mister.mike
Post by mister.mike »
I used Easyface to make a watchface -- how do I get it on to my band?
MagiicMiind
Post by MagiicMiind »
I have the .face file, how can I put it on my watch or how can I convert it to the bin file?
Thanks in advance
I did this:
