Пошук дав 3 результатів
- 27 липня 2023, 04:37
- Jump to forum
- Jump to topic
Re: Mi Band 8
I used Easyface to make a watchface -- how do I get it on to my band?
- 20 вересня 2023, 10:22
- Jump to forum
- Jump to topic
Need opinions for my new application
Mi Create is a simple to use watchface designer made for non Huami manufactured Xiaomi wearables (Xiaomi watch series, any Xiaomi band newer than the Band 7 & Redmi Watch series)
It's made to be as easy to use as possible, no pitfalls or nasty caveats, no sluggish UI and no fancy excessive features ...
- 08 січня 2024, 08:21
- Jump to forum
- Jump to topic
Re: Need opinions for my new application
Special widgets from EasyFace like WeatherIcon and WeekIcon are unsupported and do not plan to be supported, use ImageLists. Currently it is also in beta testing and is not fully polished, I will post into the main watchface topic once it's done.
