Amazfit Active
om_richard
- GIK-Team
- root
- Has thanked: 1162 times
- Been thanked: 279 times
As of now, we do not have watch faces specifically for the Amazfit Active on our platform. However, we are continuously expanding our collection, and our community of designers is always working on creating new and diverse watch faces.
It takes some time for new models to gain traction among designers, but we are optimistic that watch faces for the Amazfit Active will be available soon.
om_richard
om_richard
Now there are several watchfaces for Active, but how do I install them? It's easier to install watchfaces on Amazfit Band 7
om_richard
How to install watchface to Amazfit Active? I have entered the Mac Address, but it still can't sync to the device. What should I do?
There are watch faces for active ,but how to install them ,in the amazfitwatchfaces app ,after download,there is no option to connect to the watch
Is there any timetable to support downloading faces to the amazfit active watch? It is not possible currently to connect or download faces to the watch from the app.
- GIK-Team
- root
Currently, our app doesn't directly support downloading faces to the Amazfit Active watch. However, as an alternative, you can try downloading watch faces using QR codes through the Zepp app. This method should enable you to enjoy new faces on your Amazfit Active watch. We are continuously working to expand our compatibility and hope to include direct support for your device in the future.kckid wrote: 25 Jan 2024, 12:31Is there any timetable to support downloading faces to the amazfit active watch? It is not possible currently to connect or download faces to the watch from the app.
Thank you for the quick reply! Can I use the QR code for GTS 3/4 watch faces for the Amazfit Active? They have the same resolution, but the faces don't seem to come out clearly.GIK-Team wrote: 25 Jan 2024, 12:36Currently, our app doesn't directly support downloading faces to the Amazfit Active watch. However, as an alternative, you can try downloading watch faces using QR codes through the Zepp app. This method should enable you to enjoy new faces on your Amazfit Active watch. We are continuously working to expand our compatibility and hope to include direct support for your device in the future.kckid wrote: 25 Jan 2024, 12:31Is there any timetable to support downloading faces to the amazfit active watch? It is not possible currently to connect or download faces to the watch from the app.
- Has thanked: 420 times
- Been thanked: 2122 times
If I'm not mistaken, it can't be used because Amazfit Active has a png image encoding that is different from GTS3-4.kckid wrote: 25 Jan 2024, 16:18Thank you for the quick reply! Can I use the QR code for GTS 3/4 watch faces for the Amazfit Active? They have the same resolution, but the faces don't seem to come out clearly.
If you really want to use it, you need to convert it. Programs that can convert can be found on the forum at this link. viewtopic.php?p=11643#p11643
- GIK-Team
- root
Would it be helpful to remove the mention of Amazfit Active's compatibility with GTS 3/4 from our site? We added this based on data from the official watch face editor, but if there are real differences in encoding, maybe we should consider this. What do you think?asoo wrote: 25 Jan 2024, 17:39If I'm not mistaken, it can't be used because Amazfit Active has a png image encoding that is different from GTS3-4.
@GIK-TeamGIK-Team wrote: 25 Jan 2024, 20:42Would it be helpful to remove the mention of Amazfit Active's compatibility with GTS 3/4 from our site? We added this based on data from the official watch face editor, but if there are real differences in encoding, maybe we should consider this. What do you think?asoo wrote: 25 Jan 2024, 17:39If I'm not mistaken, it can't be used because Amazfit Active has a png image encoding that is different from GTS3-4.
As far as I tested with sasha's imagetozeppOS
It is certain that Active's and GTS3/4 png images have different encodings. in my opinion If this is the case, I think it's should removing references to both device.
Because only scripts can be used together.
As for the picture, it is unlikely that it can be used.
- GIK-Team
- root
Thanks for the valuable insights. Based on your testing with Sasha's imagetozeppOS and the differences in PNG encodings between those watch face models, we've decided to remove the message suggesting compatibility between these devices on our website.asoo wrote: 25 Jan 2024, 21:02As far as I tested with sasha's imagetozeppOS
Thanks asoo and the GIK-Team for the feedback/updates. That's unfortunate though...there are a great many watch faces for the GTS 3/4 that would be nice to have on the Active.
Basically, you can convert GTS3/4 to use with Active.
with the following requirements:
1. You must have a program that has the ability to convert from GTS3/4 to Active.
Here I recommend "Watch face editor for Amazfit watch on ZeppOS".
2. GTS3/4 dial must use the standard script specified by the conversion program.
That's it, you can convert it to use with Active.
However, if the GTS3/4 dial uses a custom script that does not meet the standards of the editing program, the conversion cannot be done or the result is incorrect, such as missing some elements created from custom script
It's a difficult question to answer. Using 3rd party created watch faces, Naturally there is a certain level of risk. But if the creator bring that watch face to tested on the real device or at least tested on a reliable program editor or simulator program and the watchface can work normally The problems you mention , It's unlikely to happen.
As far as I know I have yet to find any watch face on ZeppOS that makes the watch "Brick".
Symptoms that I have ever experienced from my own work (is not the watchface in this website)
1. The screen doesn't show up and shows a black screen (delete it and select the new screen the issue will be solved )
2. It freezes (turn off the device and then turn on it on again When the device is turned on, it will reset the system to use the official watchface in watch)
3. The symptom freezes and resets (after the watch is restart, system will choose to use official system watchface)
However, it is not impossible. If someone intends to do it to cause brick symptoms, but as far as I know, the dials on this website, before the system allowed them to be posted publicly on the website, the watchfaces were checked to a certain extent.
- idris_inan
- Has thanked: 1 time
I'm not sure which element pointer you want to see, but if you want to see an example of Amazfit Active Edge dial, you can find it on this web link.
https://amazfitwatchfaces.com/active/fr ... ctive_Edge
