Правила форуму
Аватар користувача
Been thanked: 1044 times
Контактна інформація:
Повідомлення SashaCX75 »
v18.1
Version 18.1
Востаннє редагувалось 10 вересня 2026, 17:16 користувачем SashaCX75, всього редагувалось 54 разів.
Аватар користувача
@smith725 I don't think that's a problem. The language settings are changed very rarely.
You can use resume_call() to update the text each time the screen is switched on.
I have never seen such problems with time display. I have seen mention that the time widget updates once a minute if there are no seconds. If there are seconds on the watch face, it updates every second. You can try adding seconds to the watch face (so that they are not visible if you don't need them).
smith725
З нами з: 22 жовтня 2021, 23:18
Повідомлення smith725 »
SashaCX75 писав: 30 жовтня 2023, 10:53
I built a very simple test face, with digits designed to clearly show what I see. Maybe it's just something in my environment or watch?
Just uploaded https://amazfitwatchfaces.com/gtr/view/36479 - should be viewable soon.
Аватар користувача
rush2112
З нами з: 02 квітня 2022, 10:53
Has thanked: 121 time
Повідомлення rush2112 »
@SashaCX75
Thank you for your hard work for the watch face editor just a small question, inside where is the weather display can you make a place for all GTR3 and GTR3 Pro ( A check mark for the fix of the weather icons ) You no the issue not showing night icons . just asking if it's possible:)
Thank You
Аватар користувача
@smith725 If I understand you correctly, I don't see this problem myself. And I don't remember anyone complaining about it.
Зображення
Try disabling the function to make the minutes follow the hours. Also try to change the order of displaying hours and minutes in the editor (move their elements in the table above or below).
Аватар користувача
@rush2112 Not displaying night weather icons is a problem with older watch models. This has been fixed on newer models. In my editor the weather is displayed in the standard widget and I don't plan to change it.
Some authors fix this bug themselves. But for this they do not use the standard widget of the clock, and write code that depending on the weather and time data chooses what picture to show.
Аватар користувача
rush2112
Okay, great thanks for your reply :)
But your newer model you mean the GTR4 and up....... you are not talking about the GTR3 and GTR3 Pro ?
smith725
SashaCX75 писав: 31 жовтня 2023, 09:33
Perhaps to clarify my description - the problem is transient. I tried both disabling the "follow" option and moving the minutes well out to the side. This pair of images is taken a few second apart - the first is a few seconds before 12:41, the second is a few seconds after 12:41. The watch entered AOD mode during 12:40, so the first image is the 'initial' AOD screen.
Зображення
I also tried moving hours above minutes in the 'digital time' dialog in the editor. It produced the same results.
Аватар користувача
rush2112
@SashaCX75
Small question, what is the reason on the ( GTR3 Pro ) with you watch face editor for the Steps we can use the angle and for the stress ,...calories ,hearts,, ?
Thank You
Аватар користувача
rush2112 писав: 31 жовтня 2023, 20:18
On the GTR4 and newer models, this is fixed at the firmware level. On older firmware it can only be fixed by writing additional code in the watch face.
rush2112 писав: 01 листопада 2023, 08:25
Displaying data at an angle in the editor is implemented in 2 different ways.
The first way is simply to add an additional parameter to the widget. This is the easiest way, but it works only on new models.
The second way is to calculate the position of each digit using a code. It is much more complicated, but works on all models.
Аватар користувача
@smith725 As I wrote earlier, I do not observe such a problem. So I think this problem is only ZeppOS1 or only on your watch model.
As a possible solution, you can make all numbers except "0" without transparent background. For the digit "0" use a fully transparent picture of the same size. Make the background under the left digit black, and draw "0" on the background under the right digit. Then it will be possible to enable display of leading zeros and left alignment. The result should be as you want it to be.
smith725
SashaCX75 писав: 01 листопада 2023, 09:33
I clearly need to work on my explanations. The problem is entirely with "no leading zero". Turning leading zero on leads to no problems. And - I went hunting and discovered it is very hard to find GTR 3 Pro faces that use "no leading zero" in the digital number display. This causes me to wonder if many people have previously seen this problem, but just decided to work around it.
As for the language button - as per your suggestion, I just moved to setting the language at startup. I also finished the "16 segment letters" for all the reasonably supported languages that the API can return, which did take some time. It still bothers me that I could not make the switching work, but it does not really affect the results at https://amazfitwatchfaces.com/gtr/view/36301
Thanks again for this discussion - it has been very useful and I am learning lots through both experience and discussion.
FabioZumbi12
З нами з: 02 листопада 2023, 00:57
Повідомлення FabioZumbi12 »
Is there a tutorial on how to use some advanced features of editor, like the "Editable Elements"?
Аватар користувача
TRK88PL
З нами з: 17 січня 2023, 08:23
Has thanked: 67 times
Been thanked: 40 times
Повідомлення TRK88PL »
Hey, can we get option to use Weather_Current for angle on circle on GTR3 or this is not possible to do? @SashaCX75 i mean right now we have only option to have text on circle, for min and max temperature, why can't We have option to use current temperature also on circle / angle text?
Аватар користувача
@TRK88PL The data for such inscriptions is taken from the sensor and we cannot get the value of the current temperature.
There is an option to display this data in a circle in the system font. But it will probably not work on GTR3. And I will not add this feature to the editor.
domenicopardo
З нами з: 04 вересня 2021, 18:09
Повідомлення domenicopardo »
What is Zeppos? Can I install what I download from Dropbox on Windows? Can I make dials for GTR3 PRO like with AmazFit_Watchface_Editor_2 I do for GTR2???
Thanks, I want to buy a GTR3 PRO but I want to know if I will be able to make dials afterwards.
Thank you again
Bigotesfow
З нами з: 11 листопада 2023, 13:02
Повідомлення Bigotesfow »
Hello, good afternoon!
I am a user from the other side of the ocean (Argentina) I am getting started in the development wfaces for my Amazfit Band 7 smartband.
I am using the Watchface editor (ZeppOS) and I need to know if it is possible to upload the face to my watch, to test and see adjustments before uploading it to your site.
Maybe there is a way to do it from Windows or from an Android tool to do it.
Thank you very much and greetings
I don't want to mix politics but I just want you to know that I stand in solidarity with all of you.
Аватар користувача
@domenicopardo The process of creating watch faces for the GTR3 Pro is similar to creating watch faces for the GTR2.
You cannot install watch faces directly from windows. But there are some android and apple apps to install watch faces.
Аватар користувача
@Bigotesfow I don't have an Amazfit Band 7 and I don't know what software they use to install watch faces on this model. But I know that there are such programmes for android. I think even AmazFaces app can do it.
Аватар користувача
Version 10.0
Mirror
Added support of fonts for data display (after installing such watch faces it is better to restart the watch).
Lattenknaller
З нами з: 09 серпня 2022, 08:43
Has thanked: 62 times
Been thanked: 168 times
Повідомлення Lattenknaller »
I have a question about the use of custom fonts:
What format must the font be in and where is the file then stored so that the program recognizes it?
Аватар користувача
@Lattenknaller The font must be with ttf extension in TrueType format. After adding them to the project, they will be copied to the required folder by themselves. Not all models support the use of font files.
Lattenknaller
SashaCX75 писав: 07 грудня 2023, 06:37
Thanks, so there's the mistake, ZeppOS1 can't do it (GTR3 Pro) and ZeppOS2 can (GTR4). Just tested, too bad
mrmegi
З нами з: 07 грудня 2023, 22:04
Повідомлення mrmegi »
Regarding the fonts, what does "Data display" in "Added support of fonts for data display" mean? Can ttf files be used instead of images for e.g the digital clock?
And for adding ttf file, lets say I have a project called "newFace" in the Watch_face folder, I added my ttf file to the "newFace" folder. How can I expect to use the font that I added? I can not see it while creating watchfaces. (Trying it out on a GTS 4)
And thank you for this app, love creating watchfaces with it!
Аватар користувача
Fonts should be added using the corresponding button in the editor. Then they will be available for selection.
In the current version, fonts can only be used for activities. Support for time and date fonts will be available in the next version.
Аватар користувача
BigBlind68
З нами з: 28 вересня 2023, 09:00
Повідомлення BigBlind68 »
Is there someone who can make, or maybe already made, a tutorialvideo how to build a simple watch face from scratch with the software from @SashaCX75?
I'm curious because the interface could be more user friendly imho, especially for beginners.
Відповісти
Хто зараз онлайн
Зараз переглядають цей форум: Немає зареєстрованих користувачів і 3 гостей
