Port WFP 105 for GTR3
mrbutthead
- Has thanked: 60 times
- Been thanked: 5 times
Hello friends. Please port this WF for GTR3. Thanks.
https://play.google.com/store/apps/deta ... watch_face
- Has thanked: 404 times
- Been thanked: 2022 times
This watch face was tested on GTR3 only.
Although the dial looks simple But there are a lot of elements to creating this watch face. Because the dial has changed the color of the letters. and backgrounds in two styles , so I will make this watch face will be made in only 5 colors
Download link is in the spoiler
GTR3 : GTR3pro: GTR4 :
After click change color style display will be turn off , please click on screen again for change color refresh.
Spoiler Download GTR3 GTR3Pro GTR4
mrbutthead
- Has thanked: 205 times
Amazing watchface and work. I try to convert this watchface for GTR3 Pro and editor when push to unpack watchface a message appears for unhandled exception occured and editor can't convert it. Why?asoo wrote: 18 Oct 2023, 12:14Spoiler
Download link is in the spoilerAfter click change color style display will be turn off , please click on screen again for change color refresh.Spoiler
WFP105_GTR3_Cscript.zip
you can see the file name
Cscript = Custom Script
This watchface use custom script to built , Program editor can not unpack
I convert many of your watchfaces which using custom script and editor 9.0 can convert them. Obviously something is being done with this one. Thank you for inform me.
Of course, some custom scripts Program Editor 9.0 can convert it, but not all custom scripts, because custom scripts may have specific variable values. which is not available in the editor Therefore, it is not strange that some dials The one I specified as Cscritp may be converted, but if you examine carefully, you will definitely find that some functions are missing.amazfitfacesafrica wrote: 18 Oct 2023, 13:46I convert many of your watchfaces which using custom script and editor 9.0 can convert them.
Therefore, if the script i create, if can be use the program to convert
The name of file it will have UF , US not Cscript
- UF = user_functions.js
- US = user_script
I'll specify it at the file name.
But if any file that I specify is CScript = custom script, it means that the program may be convert or may be not to convert but if it can conver it will be lacks some function to work with.
That watch face cannot be converted because I have used the translator configuration. that does not conform to the standards of the program editor To make this dial have a function that can work close to the originalamazfitfacesafrica wrote: 18 Oct 2023, 13:46Obviously something is being done with this one. Thank you for inform me.
If you really want to know what's going on with this watch face. which makes it impossible to convert You could study the script in index.js yourself.
mrbutthead
@asoo Friend, is it possible to remove these shortcomings in the numbers?
I think you didn't read what I posted in the previous thread "before downloading".mrbutthead wrote: 24 Oct 2023, 21:57@asoo Friend, is it possible to remove these shortcomings in the numbers?
I thought that if the problem was caused by faulty code, I might fix it.
But the problem is with the image. If possible, you should try to fix it yourself.
I think the work I port is work that anyone can edit. Because I did not conceal what was in my resource. So I The post says every time. If you want to fix it, please do it yourself, and I won't continue editing work that I've already ported.
Because if I have to come back and edit my work every time someone requests it in order to please them. It's probably something I can't do.
I hope you understand what I am explaining.
However, this time I will fix it for you.
I have edited some of the numbers to a level that I think is sufficient for use and have uploaded them in the download request section. But if this is still not satisfactory to anyone, Please try to fix it yourself.
viewtopic.php?p=16625#p16625
mrbutthead
mrbutthead
