G-Shock ( GTR3 Pro)
Moderadores: asoo, Watchmens
Reglas del Foro
Responder
Has thanked: 205 times
Contactar:
G-Shock ( GTR3 Pro)
Mensaje por amazfitfacesafrica »
Hello, can anyone with knowledge help me because i convert this watchface with sasha editor but colour change don't work at all. I attach the convert file here. Thank you.
https://amazfitwatchfaces.com/gtr/view/36070
Avatar de Usuario
Has thanked: 438 times
Been thanked: 2142 times
Contactar:
Mensaje por asoo »
amazfitfacesafrica escribió: 11 Oct 2023, 15:26
After unpacking , you will find user_script_start.js file in GTR3's folder.
When you're done converting, before pack you must to copy the user_script_start.js file from the GTR3's folder into the GTR3pro's folder where you converted .
Then pack it to GTR3pro.
In the Description, we have already written information about the user_script_start.js file.
Contactar:
I can't find that file (user_script_start.js) in gtr3 file after unpacking, why? I already previously convert many of your watchfaces without doing what you say and watchfaces works fine.
Avatar de Usuario
Contactar:
Mensaje por asoo »
amazfitfacesafrica escribió: 11 Oct 2023, 19:20
I do not know , why you do not find.
I tested by use Version 9.0 (available for download on this website) , After unpacking, the file "user_script_start.js" was found in GTR3's Folder as shown in the attached image.
Imagen
in this watchface use "user_script_start.js " to built , The dials you mentioned earlier can be converted because they don't use "user_script_start.js" to create them. or the added user_script does not affect the main functionality of the function.
Once you convert So those dials still work normally. But for this watch face, the user_script used has variable values configured. That affects the work of the color change function, so if you convert without following the steps I mentioned above, You will encounter the problems you have reported.
Contactar:
Thank you for help. Finally fix it.
Responder
¿Quién está conectado?
