Is there anyone that would convert this wf to TRex 2 with AOD (no second hand).? Thanks in advance!!!
https://amazfitwatchfaces.com/t-rex/view/8439
Watch face request (conversion from TRex to TRex 2)
Peepeepoopoo
- Has thanked: 441 times
It is recommended that
You should specify which version you want.
Because the watchface you requested has been made in many versions.
Because you did not specify the required version.
I convert the latest version that i found in the download catalog to Trex2
So if you want a different version than this, please edit and add it yourself.
Peepeepoopoo
Thanks for clarifying, I didn’t realize a conversion to trex2 had already been made.
