two own watchfaces
Rafi87
- Has thanked: 1 time
two own watchfaces
Hi
I have a GTR 4 Limited Edition watch and I want to ask how can I store 2 custom watch faces in the watch?
I have one own watch face in my watch, and when I upload the second one (also my own) it overwrites the one that was there, but I want to have both watch faces in my watch
- Has thanked: 419 times
- Been thanked: 2109 times
That you're talking about is likely due to
"appId": duplicate of watchface
You can change "appid" by
in ( watchface ) ".zip" after you unzip , you can found file "app.json"
you can edit this file by open it with notepad or other text editor .
Make sure the number after "appId" is unique.
Or if you use Sasha's Editor you can gen. new "appid" by click on "Generate" ( in Background element )
Rafi87
if I understand correctly, in order to be able to have two of my own watch faces, I have to edit app.json and modify the appId?
I create watch faces in the program Amazfit_WatchFace_Editor_(ZeppOS) by SashaCX75 and in this program you can choose the ID, see photo
if I generate a new ID, could I have two dials stored in the watch?
Yes, you got it right.Rafi87 wrote: 29 Jul 2023, 09:14Spoiler
If the ID is different, the watch face will be kept. In the watch is another dial.
If the IDs are the same, they are stored overwrite .
from the picture you show I see you are still using Sasha's editor Version 8.0.
I recommend you to switch to 8.1, you can download from the link below.
viewtopic.php?p=16065#p16065
Users browsing this forum: No registered users and 23 guests
