Sector 13+ (GTR3 Pro)
- Has thanked: 205 times
- Been thanked: 5 times
Hello to all. Can anyone with knowledge to convert this watchface exactly as it is because uses custom script to made and can't convert with editor properly. Thank you for all your help.
https://amazfitwatchfaces.com/gtr/view/34574
- Has thanked: 409 times
- Been thanked: 2037 times
amazfitfacesafrica wrote: 12 Jul 2023, 14:57Hello to all. Can anyone with knowledge to convert this watchface exactly as it is because uses custom script to made and can't convert with editor properly. Thank you for all your help.
This watch face consumes a lot of device resources if used it maybe Showing slowness in some cases, such as selecting, changing colors, etc. is normal. Including energy consumption by consuming more energy than usual
Fixed issue image minute51 show not correct :
All Function work same as GTR3 Version :
Thank you for reporting the error.
It's also on GTR3, I've checked. Found that the problem is caused by using more than 20 images of battery image progress. I fixed it and tested it on GTR3. It works fine.
You can download it in the original post.
viewtopic.php?p=16042#p16042
