JN_EXO (GTR3 Pro)
- Has thanked: 205 times
- Been thanked: 5 times
JN_EXO (GTR3 Pro)
Hello. I try to convert this watchface with Sasha editor but while the image of watchface appear with steps and other progress don't show numerical values font at all. Either steps, power and distance don't show. Can anyone with knowledge convert this watchface for GTR3 Pro. Thank you and thanks to asoo for this amazing watchface. https://amazfitwatchfaces.com/gtr/view/33646
- Has thanked: 438 times
Version 7.3 final can not convert this watchface because have a new element and function in this watchfaceamazfitfacesafrica wrote: 16 May 2023, 19:40Hello. I try to convert this watchface with Sasha editor but while the image of watchface appear with steps and other progress don't show numerical values font at all. Either steps, power and distance don't show. Can anyone with knowledge convert this watchface for GTR3 Pro. Thank you and thanks to asoo for this amazing watchface. https://amazfitwatchfaces.com/gtr/view/33646
I create this watchface for test "program editor version beta" only , I can make version GTR3pro for you
B u t , If there is any mistake, I will not fix it. Because it's still in testing only and I don't have GTR3pro to test it, so if the display is not correct or does not meet your needs Please make further modifications directly in the index.js file yourself.
The details of the dial are the same as GTR3.
Can be viewed at the link:
Can Found Link download GTR3pro version in spoiler
Thank you, everything works ok and seems fine. Amazing watchface.
Is it possible to add more colours at hands and at dial like GTR3? If not all colors as in version 3, at least four or five primary colors. Whatever is easiest for you.
One of your best watchfaces for the me. Thank you.
viewtopic.php?p=15688#p15688amazfitfacesafrica wrote: 17 May 2023, 13:52Is it possible to add more colours at hands and at dial like GTR3? If not all colors as in version 3, at least four or five primary colors. Whatever is easiest for you.
Lattenknaller
- Has thanked: 62 times
- Been thanked: 168 times
Do I have your permission to edit this very nice WF? I am missing e.g. the AOD and other little things. I'm just a translator and not a BETA tester and don't have access to the 7.4 but AOD and some small changes I can do in the Index.js.
That OK , Please do it.Lattenknaller wrote: 17 May 2023, 19:59Do I have your permission to edit this very nice WF? I am missing e.g. the AOD and other little things. I'm just a translator and not a BETA tester and don't have access to the 7.4 but AOD and some small changes I can do in the Index.js.
Lattenknaller
