Ad blocker detected: Our website is made possible by showing ads to visitors. Please consider supporting us by disabling your ad blocker on our website.
If you experience any problems with the forum (it is not visible, there is no way to post messages, or some functionality does not work), please
let us know .
If you have problems with registration or you did not receive confirmation letter,
let us know and we will activate your account manually.
If you get an "The submitted form was invalid. Try submitting again" error,
delete cookies , then try again.
Moderators: asoo , Internal error , Watchmens
Posts: 1033 Joined: 22 Mar 2018, 10:00
Has thanked: 1181 times
Been thanked: 281 times
Post
by GIK-Team » 15 Mar 2019, 20:22
Amazfit WatchFaces is the largest watchface collection in the world for Amazfit watch. Instantly get everything you need to customize & personalize your Amazfit watch!
Join the thousands and get access to 180 000+ amazing watchfaces! With a huge number of new watchface that are added every day!
One app! And more than 180 000 watchface!
AmazFaces BETA on Google Play
Post
by GIK-Team » 30 Mar 2019, 08:47
Antotamara wrote: 29 Mar 2019, 23:04
No funciona en mi stratos
Can you, please, explain little bit more clear? What exactly does not work for you and how you use our application. Thank you!
Post
by GIK-Team » 31 Mar 2019, 19:03
FashionUomo wrote: 31 Mar 2019, 15:47
Non funziona su amazfit stratos
Kamakzie
Post
by Kamakzie » 05 Apr 2019, 05:58
When I try to download a watch face it gives me the error that it can't connect to the watch. Any ideas?
Post
by GIK-Team » 08 Apr 2019, 17:26
Kamakzie wrote: 05 Apr 2019, 05:58
Update version
Greg
Post
by Greg » 09 Apr 2019, 07:15
hello
pls tell me how can i install this app on my watch
Post
by GIK-Team » 09 Apr 2019, 16:14
Greg
Post
by Greg » 09 Apr 2019, 17:20
Erkuky
Posts: 1 Joined: 19 Apr 2019, 19:35
Post
by Erkuky » 30 Apr 2019, 13:52
Poner aqui el link para descargar la APK a instalar en el Watch.
Es mas trabajoso si solo podemos bajarlo al smartphone desde la app del smartphone.
Saludos
merry007
Post
by merry007 » 11 May 2019, 09:55
Really nice
merry007
Post
It helped me a lot.
rosey12
Post
by rosey12 » 22 May 2019, 04:37
Wow. This is just awesome. Is the updated version suitable for ASUS device? Please help me with a suitable solution.
Post
by GIK-Team » 22 May 2019, 06:13
rosey12 wrote: 22 May 2019, 04:37
Requires Android
5.0 and up
Notoriez
Post
by Notoriez » 22 May 2019, 09:35
I've installed the app and it's working fine. Some of the watch faces that i downloaded via the AmazFaces appears on the Amazfit App.
But there is also quite few watchfaces that i tried to downloaded is not appearing on the app after few tries. Any reason for this?
Great job btw.
Post
by GIK-Team » 22 May 2019, 19:48
Notoriez wrote: 22 May 2019, 09:35
Great job btw.
What watchfaces did not appear? Can you provide links?
dpisaacs
Posts: 1 Joined: 26 May 2019, 23:22
Has thanked: 1 time
Post
by dpisaacs » 26 May 2019, 23:58
Hi, I've downloaded and installed the app on my phone and the watch companion apk (on Stratos).
Just curious as to what the installed companion app on the watch calls itself?
Using the APK Installer, I can see an app that I suspect it might be called is "com,st,receiverwatch", is this it?
osmat
Admin
Posts: 278 Joined: 22 Mar 2018, 10:09
Has thanked: 35 times
Been thanked: 73 times
Post
by osmat » 27 May 2019, 06:27
Yes that's right com.st.receiverwatch
daydreaming
Posts: 4 Joined: 11 Aug 2018, 07:25
Post
by daydreaming » 08 Jun 2019, 23:00
In some reasons, i can't use Google play in China.
Is there any other way to download the AmazFace app?
TXK
Posts: 302 Joined: 10 Apr 2018, 05:15
Has thanked: 150 times
Been thanked: 99 times
Post
by TXK » 09 Jun 2019, 12:16
On PC, display:
403 Forbidden
Post
by GIK-Team » 09 Jun 2019, 12:46
