Convertion GTR to GTR3
Max83
Post by Max83 »
Hi, can someone convert from gtr to gtr3 this?
thank you very much
https://amazfitwatchfaces.com/gtr/view/5353
eng_pipboy4000_packed_zip-182720-1f81a747f1.bin
(488.22 KiB) Downloaded 121 times
Has thanked: 421 times
Been thanked: 2128 times
Max83 wrote: 18 Mar 2023, 19:31
thank you very much
- If the watch face that can be converted with an editor ( Last Version ) available on the web. viewtopic.php?p=11643#p11643
If have a request. I will only convert, I will not review the original. The person requesting, please verify the correctness. and if there is any error from the original , please ask the owner of the work or please edit it yourself (for example, GTR3 converted to GTR4 or GTR3Pro )
PipBoy4000_GTR3.zip
(282.29 KiB) Downloaded 114 times
Max83
Post by Max83 »
asoo wrote: 19 Mar 2023, 13:01
PipBoy4000_GTR3.zip
Thanks, how I can modify with WatchFace editor? I try to open the project but is impossible...
I would modify with the AOD...
thanks
Max83 wrote: 27 Mar 2023, 18:05
thanks
??? what editor version you use ?
Now the new version is 7.1 , I tested it can unpack this normally.
Link editor :
Max83
Post by Max83 »
I have tryed with the 7.0 and now with the 7.1.
Impossible to unpack. idk...
Max83 wrote: 28 Mar 2023, 16:30
I also don't know why you can't unpack this watchface with Version 7.1.
I tested and can unpack normally.
See tested in spoiler .
Max83
Post by Max83 »
is empy
Max83 wrote: 29 Mar 2023, 13:54
is empy
Your picture show you use program Version 7.0 ,
you can download 7.1 version and try
Like download Version 7.1
Max83
Post by Max83 »
found the problem... with the version 7.1 antivirus block all... now found it...
I trued also to open this but is impossible. (is for band 7)..
you can check?
pipboy_ab7-234311-f7b108da07.zip
(198.94 KiB) Downloaded 105 times
Max83 wrote: 29 Mar 2023, 14:05
you can check?
That watchface can not read index with SashaCX75 editor because the owner make it by use custom coding script , so if you want more information about that watchface recommend to ask the owner
Recommend. If you want to ask a question that is not related to the topic, I recommended to open a new topic.
Max83
Post by Max83 »
ok... thanks mate...
