Request for NASA watchface [GTR 3]
TRK88PL
Has thanked: 67 times
Been thanked: 40 times
Post by TRK88PL »
Hey, can somebody convert this wf for GTR 3?
https://amazfitwatchfaces.com/gtr/view/32277
I think DopeWatch wouldn't have problem with converting this to another devices.
Has thanked: 205 times
Post by amazfitfacesafrica »
TRK88PL wrote: 16 Mar 2023, 12:43
You must ask for permission first i think.
TRK88PL
Post by TRK88PL »
I think it's enough :)
Has thanked: 436 times
Been thanked: 2137 times
TRK88PL wrote: 16 Mar 2023, 13:16
This watch face using a custom and coded set of commands, I've unpacked and tried to make the functions look the same as the original.
This watch face I created uses all the resources images from the original and some modifications. Therefore, this watch face may have some functions that are not the same as the original.
analog may be work a little different
- animation image is to big sometime it will not move smooth
- animation will not same the watchface original
I would like to tell everyon a little more.
Next, if any watch face is encoded " index.js " and have someone conversion request has been made I might not do it Because the owner of the encrypted instruction set must have his reasons to do that.
<< last for convert watchface use script custom and coded >>
NASA_GTR3Pro_Cscript.zip
(459.45 KiB) Downloaded 121 times
NASA_GTR3_Cscript.zip
(404.58 KiB) Downloaded 144 times
TRK88PL
Post by TRK88PL »
Wow, just incredible, You can convert everything, awesome job! THANK YOU!
