Help convert Twnty4 v.1.0.7 for GTR3 Pro
- Has thanked: 205 times
- Been thanked: 5 times
Hello guys,can anyone with knowledge convert this watchface from T_5 for GTR3 Pro as it is.
Thank you for your help and support. T_5 already give his permission.
https://amazfitwatchfaces.com/gtr/view/32204
Lattenknaller
- Has thanked: 60 times
- Been thanked: 132 times
all credits to T_5
sunrise and sunset pointer I did not get so right. You have to test it. The rest is taken over 1 to 1.
edit:
I have just tested myself: the display of sunrise and sunset is not suitable for the 24h display of the analog clock. Always shows wrong times. Have therefore taken it out completely. (Twnty4_GTR_3_Pro_woSun.zip)
Maybe another knows more....
edit:
- Attachments
Twnty4_GTR_3_Pro_woSun.zip- (143.06 KiB) Downloaded 124 times
Twnty4_GTR_3_Pro.zip- (143.13 KiB) Downloaded 147 times
A big thanks to Lattenknaller for convertion and to T_5 for his permission. Sunset and sunrise don't work, if it's possible to make it work that would be great otherwise if not if it is easy remove it completely. Thank you. Much appreciated. I attach photos to see. If someone has the knowledge to make work the sunset and sunrise function like T_5 GTR4 version it would be great.
Lattenknaller
I saw it, thank you again.
Is it possible to have this one converted to the GTR 3?
Very nice watch face indeed!
- Has thanked: 415 times
- Been thanked: 2082 times
This watch face has a script code that is not standard script.amazfitfacesafrica wrote: 14 Mar 2023, 12:00Spoiler
https://amazfitwatchfaces.com/gtr/view/32204Spoiler
Therefore, this set of watchface I can only edit coordinates
- Adjust the image size to fit device.
- Fixed various point coordinates as far as I can guess.
If the download is already displayed incorrectly, I cannot fix it.
I've tested it with the GTR3 so far I haven't found any issues yet.
GTR3 pro I can't test it. can only edit the calculated coordinates
ืnote :
- Use the script of the original, change only the coordinates. Therefore, the display is expected to be the same as the original.
if the owner wants it to be deleted Please notify the requester.
Do not inform the helper to convert.
I think it would be difficult to add any element to the coded script. If you want to add an element, it's better to request the owner of the watch face.TRK88PL wrote: 15 Mar 2023, 15:00Awesome... Yeah I know this is not how this was projected but..Maybe someone could add seconds under minutes? In smaller font... I only miss this in this watchface.
