How can I convert the GTR watchface to GTR 3 Pro ?
eddiehsieh
Post by eddiehsieh »
Is there a way to convert the GTR Bin file to the GTR 3 Pro Zip file?
I like this watch face.
https://amazfitwatchfaces.com/gtr/view/9837
But I don't know how to convert it.
Can anyone help me?
Thanks......
Has thanked: 441 times
Been thanked: 2142 times
eddiehsieh wrote: 08 Mar 2023, 15:39
Can anyone help me?
Thanks......
Can change type watchface by click on logo ( Omega )
Full AOD show only Type 2 ( Black Version )
snoopy_Cscript_GTR_3_Pro.zip
(371.59 KiB) Downloaded 48 times
eddiehsieh
Wow
Thank you !!!!!
I'm very grateful ......
Could you tell me how to convert ?
Maybe some hint.
I want to learn about it, if I can help other people next time .....
Thanks again.
I really like this watch face very much....
You really help me ....
:D :D :D
asoo wrote: 08 Mar 2023, 17:19
Can anyone help me?
Thanks......
eddiehsieh wrote: 09 Mar 2023, 03:18
Wow
Thank you !!!!!
Maybe some hint.
Thanks again.
:D :D :D
If you want to do this with your own the most important thing You must be able to use image editing software well. To be used to separate different elements from the original image or create new elements to look like the original
Which I cannot recommend in this respect, it depends on experience and expertise. of each person Therefore, so you must practice and gain experience by yourself.
In the creation of the watch face It wouldn't be difficult. You can find the program that can be used to create dials on this web
Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3)
eddiehsieh
Thanks for reply so soon.
Sorry for that I didn't make it clear.
I think image editing software is not a big problem.
For example, I want to modify the "GTR Omega Snoopy Collection".
I tried the "AmazFit WatchFace editor for Windows by SashaCX75".
It can uncompressed the image files.
Should I use the "Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3)" to make the watch face?
This is the biggest problem for me. :lol: :lol:
I will try to modify/make a watch face.
Thanks again.
asoo wrote: 09 Mar 2023, 03:54
eddiehsieh wrote: 09 Mar 2023, 04:44
Thanks again.
It is possible to create watch faces that use standard functions similar to the official editor.
But the snoopy watch face has a custom script added, cannot be edited with the Editor. You need to learn more about the custom script.
You can see an example script in the index.js file in the .zip file.
To edit the index.js file, you can use a text editor ( notepad ) to edit it.
More information you can find on this web.
Most of the custom scripts that I bring from "SashaCX75" and "WAX" .
SashaCX75 :
Link is on this message "Сollection of code examples for use in watch faces." in the topic
WAX :
All WAX's watchface
https://amazfitwatchfaces.com/search/gt ... rID/660711
eddiehsieh
Thank you for the information.
This is really helpful.
I'll study for that.
asoo wrote: 09 Mar 2023, 05:19
SashaCX75 :
WAX :
All WAX's watchface
