[GTR 4] Creation of WatchFace
danduartte
Post by danduartte »
Hello friends!
I wonder if someone could create this watchface for the GTR 4:
Thank you very much!!!
danduartte
asoo You who are an expert guy, could you make this watchface for me, please?
Been thanked: 2093 times
danduartte wrote: 23 Feb 2023, 16:42
@asoo You who are an expert guy, could you make this watchface for me, please?
Sorry , Now I am not interest to receive any requests.
Because , I don't have time because I have a lot of work to do right now.
Ps.
I have some additional recommendations:
The image you use as a sample should be a high quality image. Or at least the resolution should be equal to or greater than the watch face of your desired device.
in order to bring that image to be edited to create a watch face
danduartte
It's a pity that you are busy and can't make this dial. But thank you for the answer!
danduartte wrote: 23 Feb 2023, 23:05
danduartte
i will try in this holiday
danduartte
Please read in "spoiler" Carefully
You can see link download in "Spoiler"
Because I don't have much time to do it.
For this watch face, I only took images from sources where I could find them.
Original image quality is 400x400, so the image of the watch face is only usable.
I haven't tested it on real devices. Just testing on the editor program only.
This dial that I have completed. I will not to receive for any further corrections.
If there are any mistakes, please correct them yourself. using the editor program that can be found on this web.
viewtopic.php?t=2743
Anyone who is interested, please manage the risk of use by yourself.
I cannot take any responsibility for the results that will occur on real devices.
Function in this watchface :
- stand up
- step
- Distance
- Heart rate
- Time Digital
- Analog seconds
- day month year
- alarm , bluetooth
- Shortcut
- Full AOD
Image.Image
Garmin_FAOD_GTR4.zip
(182.94 KiB) Downloaded 35 times
Garmin2_FAOD_GTR4.zip
(219.26 KiB) Downloaded 45 times
danduartte
asoo The watchface is simply amazing, you did an amazing job!
Just a detail, do you think you could remove this black circle around it and leave everything white?
The hour numbers could be even bigger without that black part that goes around marking the seconds!
But in advance I thank you for being generous with me!
danduartte wrote: 24 Feb 2023, 12:31
@asoo The watchface is simply amazing, you did an amazing job!
Please read the spoiler carefully.
This time I will modify it.
viewtopic.php?p=14986#p14986
Next time, if you want to edit anything more, Please do it yourself.
It's not difficult to fix from. The finished dial
danduartte
asoo is that I don't know how to modify it. But I can try to learn! Thank you very much for your kindness!
