How to export Watchface package as .zip file ?
Moderatori: asoo, Watchmens
joymb
Messaggio da joymb »
When I export the watchface package from Zepp Watch Face Maker web application, the package is downloaded as .zab file. How can I download it as .zip file ? So that I will be able to load the watch face into the watch using Amazefaces android app.
Been thanked: 2117 times
Messaggio da asoo »
what device do you use ?
if device is GTR3 / GTR4
zab is a zip format, you can use WinRar to open it.
easiest way You change the zab file extension to zip and open it with winrar, you will see a watchface file with .zip in it.
joymb
I am using GTS 4 mini. Is it same of GTS 4 mini?
