Convert G-307 for GTR3 Pro
- Has thanked: 205 times
- Been thanked: 5 times
Hello again, i try to convert this watchface for GTR3 Pro with sasha editor but some objects are not displayed as it should be, that's why I'm asking anyone who can and has knowledge only convert this watchface as it is. Thank you.
https://amazfitwatchfaces.com/gtr/view/28858
- Has thanked: 417 times
- Been thanked: 2093 times
This watchface can not convert by use Sasha's program because it use custom script and SA version make by Sasha's program 5.1 beta cannot open or convert by Version 5.0amazfitfacesafrica wrote: 04 Nov 2022, 17:22Hello again, i try to convert this watchface for GTR3 Pro with sasha editor but some objects are not displayed as it should be, that's why I'm asking anyone who can and has knowledge only convert this watchface as it is. Thank you.
What Color font (number) and What version you want to request convert to GTR3pro ?
Can click on screen to change main screen same as GTR3 Version
Good morning and have a nice weekend. Thank you, works perfectly.
Is it difficult to convert version 2 with the options of analog seconds and Show / Close Digital shadow to same version already convert for GTR3 Pro? I mean, it wants to port or convert from the beginning or the existing one can be modified?
It not difficult to do , only add 2 image ( shadow , second hand ) and add script function on/offamazfitfacesafrica wrote: 08 Nov 2022, 12:19Is it difficult to convert version 2 with the options of analog seconds and Show / Close Digital shadow to same version already convert for GTR3 Pro? I mean, it wants to port or convert from the beginning or the existing one can be modified?
If you want to learn to do it yourself I've attached the finished file as an example in a topic I've posted earlier.
viewtopic.php?p=14187#p14187
Thank you so much, I will try it.asoo wrote: 08 Nov 2022, 13:57It not difficult to do , only add 2 image ( shadow , second hand ) and add script function on/offamazfitfacesafrica wrote: 08 Nov 2022, 12:19Is it difficult to convert version 2 with the options of analog seconds and Show / Close Digital shadow to same version already convert for GTR3 Pro? I mean, it wants to port or convert from the beginning or the existing one can be modified?
