Hey, is it possible for someone to convert this watchface:
https://amazfitwatchfaces.com/gts/view/9873
to a GTS 2 Mini Watchface?
Im having struggles to do it myself.
Thanks in advance : )
Request to convert a watchface from GTS3 and/or GTS4 to GTS 2 Mini
SilexMilex
- Has thanked: 425 times
- Been thanked: 2131 times
i think it can't Converts to look exactly like GTS3/4 as GTS2min doesn't have some elemente present in GTS3/4.SilexMilex wrote: 04 Nov 2022, 16:14Hey, is it possible for someone to convert this watchface:
from the use of official tools and third-party tools This can be done like this.
I don't have GTS2mini, I can't test it on a real device.
If used, please do it at your own risk.
If the watch face does not work same as preview picture. I can't fix anything, you have to study it and fix it yourself.
This watchface not work deleted
SilexMilex
I can't fix this part.
I just made a watch face from Official tools available on request only.
In the implementation section, the requester must test it himself. I cannot be held responsible for the consequences.
I'm not sure if this will fix the problem in GTS2mini.
You try to bring the watch to charger and try to open the zepp program to see if it can connect with the clock or not. if can connect the watch then added one official watch face.
