Convert G-307 for GTR3 Pro
Has thanked: 205 times
Post by amazfitfacesafrica »
Hello again, i try to convert this watchface for GTR3 Pro with sasha editor but some objects are not displayed as it should be, that's why I'm asking anyone who can and has knowledge only convert this watchface as it is. Thank you.
https://amazfitwatchfaces.com/gtr/view/28858
Been thanked: 2120 times
amazfitfacesafrica wrote: 04 Nov 2022, 17:22
This watchface can not convert by use Sasha's program because it use custom script and SA version make by Sasha's program 5.1 beta cannot open or convert by Version 5.0
What Color font (number) and What version you want to request convert to GTR3pro ?
Thanks for info, i prefer the first version not the white, this with blue and white font.
Image.Image
G307_FAOD_script_GTR_3_Pro.zip
(537.45 KiB) Downloaded 57 times
G307_V2_FAOD_Scritp_GTR_3_Pro.zip
(543.51 KiB) Downloaded 37 times
Can click on screen to change main screen same as GTR3 Version
Good morning and have a nice weekend. Thank you, works perfectly.
Is it difficult to convert version 2 with the options of analog seconds and Show / Close Digital shadow to same version already convert for GTR3 Pro? I mean, it wants to port or convert from the beginning or the existing one can be modified?
amazfitfacesafrica wrote: 08 Nov 2022, 12:19
It not difficult to do , only add 2 image ( shadow , second hand ) and add script function on/off
If you want to learn to do it yourself I've attached the finished file as an example in a topic I've posted earlier.
viewtopic.php?p=14187#p14187
asoo wrote: 08 Nov 2022, 13:57
Thank you so much, I will try it.
