Request for GTS 2 mini
DanielKarpachoue
Hey, guys!! Can anyone convert this watchface https://amazfitwatchfaces.com/gts/view/9648. I would appreciate
- Has thanked: 417 times
- Been thanked: 2092 times
DanielKarpachoue wrote: 04 Oct 2022, 16:36Hey, guys!! Can anyone convert this watchface https://amazfitwatchfaces.com/gts/view/9648. I would appreciate
- Not test on real device , only tested on editor
- I will not sure it can work or not. I just try to make it with this tool
viewtopic.php?p=12537#p12537
- If some element not work I could not fix it .
note :
What pointers do not appear ?
if you mean Pointers on the Top ( left , right )
That , It's only image show, I just port form original . The original it's only image show so I will port same as original.
fix by use script for watchface that it's can use normal.
but not sure it's work or not
if not work , I probably won't be able to fix it either.
viewtopic.php?p=13889#p13889
