Port watchface GTR3 pro
SleepyHollow
- Has thanked: 30 times
- Been thanked: 2 times
Hello to forum, can anyone helpme and port this watchface for GTR3 Pro in blue cyan like photo and is welcome any ideas for this watcface. Thank you for support.
- Has thanked: 438 times
Normal : Can change color same as GTR3 Version
https://amazfitwatchfaces.com/gtr/view/28311
note :
SleepyHollow
Thank you so much, it's perfect but i attach a photo to see 2 lines behind digital hour numbers and in the middle of hour and minutes. In the preview here there are no lines. Can fix it? May I ask a question? It is difficult for someone to add other colors with the wax code like your and wax watchfaces? Thank you.
I am not sure , I can fix it or not , Because this issue must be tested on real device.SleepyHollow wrote: 14 Oct 2022, 09:40Thank you so much, it's perfect but i attach a photo to see 2 lines behind digital hour numbers and in the middle of hour and minutes. In the preview here there are no lines. Can fix it? May I ask a question? It is difficult for someone to add other colors with the wax code like your and wax watchfaces? Thank you.
in the editor displayed correctly.
however I've tried increasing the black border size but not sure if that fixes the problem. If the fix does not resolve the issue You must try it yourself.
You can download again
viewtopic.php?p=13974#p13974
SleepyHollow
SleepyHollow
I can convert to GTR3pro But after convert, if the display is not correct same preview , I will not fix it, because I don't have GTR3pro to test. and have many element must to test on real device. If you agree as I described I will convert for you
SleepyHollow
asoo wrote: 14 Oct 2022, 12:16Spoiler
You can download in here :
SleepyHollow
Thank you so much, i test it and it's ok as the preview. Have a nice weekend.
