• Administrador
Request for GTS 2 mini
Moderadores: asoo, Watchmens
Reglas del Foro
Responder
DanielKarpachoue
Contactar:
Mensaje por DanielKarpachoue »
Hey, guys!! Can anyone convert this watchface https://amazfitwatchfaces.com/gts/view/9648. I would appreciate
Avatar de Usuario
Been thanked: 2120 times
Mensaje por asoo »
DanielKarpachoue escribió: 04 Oct 2022, 16:36
- Not test on real device , only tested on editor
- I will not sure it can work or not. I just try to make it with this tool
viewtopic.php?p=12537#p12537
- If some element not work I could not fix it .
Imagen
Ultar_1x1_GTS2mini_packed.bin
(690.34 KiB) Descargado 40 veces
note :
Olavonix
Contactar:
Mensaje por Olavonix »
did not work, pointers do not appear
Avatar de Usuario
Mensaje por asoo »
Olavonix escribió: 22 Oct 2022, 17:08
What pointers do not appear ?
if you mean Pointers on the Top ( left , right )
That , It's only image show, I just port form original . The original it's only image show so I will port same as original.
Olavonix
Contactar:
no im so sorry, the hour, minute and second hands
Avatar de Usuario
Mensaje por asoo »
Olavonix escribió: 23 Oct 2022, 17:03
fix by use script for watchface that it's can use normal.
but not sure it's work or not
if not work , I probably won't be able to fix it either.
viewtopic.php?p=13889#p13889
Olavonix
Contactar:
Worked!! Thx Asoo
Responder
¿Quién está conectado?
