Hi I wanted to request conversion of few Pip-Boy themed watchfaces from GTR 47 to GTR 3 PRO
https://amazfitwatchfaces.com/gtr/view/12440
https://amazfitwatchfaces.com/gtr/view/5353
https://amazfitwatchfaces.com/gtr/view/3513 - This one seems to be already ported but the distance meter appears to be broken (It looks like small checkerboard, and does not update) - Not needed as per comment below.
I'm sorry for inconvenience but I couldn't find any tutorial on how to convert watchfaces from old GTR's to the new ones. Every time I tried to search for something regarding conversion I got an error stating that the words are "too common". Is there any guide on conversion available on this forum?
[GTR 3 PRO] Conversion of watchfaces from GTR 47mm to GTR 3 PRO
- Has thanked: 441 times
This Version https://amazfitwatchfaces.com/gtr/view/3513 you can found in this link.
viewtopic.php?p=12083#p12083
Distance is not broken , that you can see it's a small checkerboard because Distance not have "line progress".
Oh, okay I wasn't aware of this. Thank you very much for the explanation.asoo wrote: 27 Sep 2022, 12:13This Version https://amazfitwatchfaces.com/gtr/view/3513 you can found in this link.
As far as I know , not have program convert gtr to gtr3 / 3proVa5syl wrote: 27 Sep 2022, 11:28I'm sorry for inconvenience but I couldn't find any tutorial on how to convert watchfaces from old GTR's to the new ones. Every time I tried to search for something regarding conversion I got an error stating that the words are "too common". Is there any guide on conversion available on this forum?
But i have some trick to do GTR47 to GTR3 / GTR3PRO
1. You must arrange the weather icons correctly according to the GTR3 / GTR3PRO specification, because in some GTR47 watchfaces the icon weather does not sort the icon "unknow weather" in the 26th order.
2. You need to add 29 weather icons to the GTR3 / GTR3PRO style, because the GTR47's icon weahter has only 26, the missing one is an icon.
- cloudy night
- rainy night
- clear night
3. You have to make edits to the Bluetooth picture.
Because the GTR47 can use the BT icon to show both on and off status.
But GTR3 will use the icon to show the BT status to OFF only.
So if you must to modify this section to compatible the GTR3.
For example, in the main screen, the BT state may be set to ON and the icon BT in the OFF state may be created for display.
4. The Rotation center (analog clock) x,y of the GTR47 and GTR3 / GTR3PRO may differ slightly, with GTR47mm 0,0 being centered, but in GTR3 it is set to 227,227. , GTR3PRO 240,240
Also, in the Circle progress section, there may be a slightly different angle setting.
But in this part, it's not so important. Because you can modify it on the Program editor. As you build GTR3
5. You need to understand the order of the elements' layers. I can't recommend this section. You will need to learn more from your device in order to properly display the images on the watchface.
6. You must to use the image editing program is very well. Because in order to convert the watchface of the device. You have to edit the images in order to get the effect according to the specifications of the device. In this respect, In this case I can not recommend . Because it must depend on experience individual
7. If you want to port GTR to GTR3PRO you must to resize all image , Because the two devices have different sizes. by GTR and smaller than GTR3PRO
So you need to upsize GTR's image of about 105.8%.
You can use this program https://www.bricelam.net/ImageResizer/ for resize multi file in one time.
Or you can use resource GTR to make GTR3 after finish , you can convert to GTR3pro on program editor
- cloudy night
- rainy night
- clear night
This version https://amazfitwatchfaces.com/gtr/view/12440 you can found in this link :
viewtopic.php?p=11259#p11259
