Request for GTS 2 mini
Hello there, anyone please can convert this watchface https://amazfitwatchfaces.com/gts/view/8346 for GTS 2 Mini?
- Has thanked: 417 times
- Been thanked: 2092 times
Ohag wrote: 22 Sep 2022, 20:11Hello there, anyone please can convert this watchface https://amazfitwatchfaces.com/gts/view/8346 for GTS 2 Mini?
- Not test on real device , only tested on editor
- I will not sure it can work or not. I just try to make it with this tool
viewtopic.php?p=12537#p12537
- If some element not work I could not fix it .
- If have some issue please do not ask me because i can not test on real device.
- value of UV in Preview not show but in the script have it , I'm also not sure why.
It might be that Program pack/unpack doesn't support previewing in this section, but the script is rendering correctly.
Tested by Ohag it's work normal.
note :
I instaled on my gts 2 mini and just the 2 digtis of hours doesnt appear :/
Have someway can i edit or test this watchface to appear the hours digits on other program or site?
thank you in advance
I am not sure this is can fix your issue or not .
Please download again , this is my try to fix :
But if it not work i will delete it .
You can download in the original topic :
viewtopic.php?p=13820#p13820
My note :Fix by remove Delimiter
Yeah, doesnt appears the hours digitasoo wrote: 24 Sep 2022, 02:05I am not sure this is can fix your issue or not .
Anyway, thanks for all the work.
OhagOhag wrote: 24 Sep 2022, 04:27Spoiler
last attempt
If it still doesn't show, I'll delete it.
thank you for testing
My note : change unknow = 1
WORKEDasoo wrote: 24 Sep 2022, 05:48Spoiler
@OhagOhag wrote: 24 Sep 2022, 04:27Spoiler
last attempt
Thanks so much!
